Var of Sum of Random Variables when n is a Random Variable?
  • Context: Graduate
  • Thread starter Thread starter jimmy1
    Sum Variance
The discussion revolves around the variance of the sum of independent and identically distributed random variables when the number of variables, denoted as n, is itself a random variable. Participants explore the implications of this scenario on the variance calculations and the validity of established formulas.
  • One participant states that the formula Var(∑_{i=1}^{n}X_i) = ∑_{i=1}^{n}Var(X_i) does not hold when n is a random variable.
  • Another participant applies the Law of Total Variance to derive Var(∑_{i=1}^{n}X) and suggests it results in E[n]Var(X1) + Var(n)(E(X1))^2.
  • A later reply questions the correctness of the terms used in the variance calculations and suggests that Var[E[∑_{i=1}^{n}X|n]] should be Var[nμ] instead of Var[nμ|n].
  • One participant agrees with the assertion that the initial formula does not hold when n is a random variable and acknowledges a previous error in their own calculations.
  • Another participant discusses special cases, noting that if the mean μ is zero, the complex formula simplifies to the simpler one, and highlights the relationship between the correlation of the sum and n.
  • A participant expresses confusion over the notation used for n and N, indicating difficulty in understanding the variance results derived from the Law of Total Variance.
Participants generally agree that the formula Var(∑_{i=1}^{n}X_i) = ∑_{i=1}^{n}Var(X_i) does not hold when n is a random variable. However, there are multiple competing views regarding the correct application of the Law of Total Variance and the implications of specific cases, indicating that the discussion remains unresolved.
Participants highlight limitations in their calculations, including assumptions about the mean and variance of the random variables involved, as well as the notation used for n and N, which may lead to confusion in the derivations.
jimmy1
If I have a set of indepenent and identically distributed random variables X1,...Xn, then [tex]Var(\sum_{i=1}^{n}X_i) = \sum_{i=1}^{n}Var(X_i)[/tex].
Now I want to know what the sum of variances of Xi would be when n is a random variable?
I'm guessing the above statement still holds when n is a random variable, but when I work out both sides of the above statement, I get two different answers.
For example, [tex]Var(\sum_{i=1}^{n}X_i)[/tex] will now be the variance of a random sum of random variables which can be worked out using the total law of variance, and comes out as E(n)*Var(X1) + Var(n)*E(X1)^2.
But evaluating the other side of the expression [tex]\sum_{i=1}^{n}Var(X_i)[/tex] when n is a random variable comes out as E(n)*Var(X1).
So, I don't understand why I'm getting two different answers here?? Which one is correct?? I think they should be the same.
The first equation (var(sum)=sum(var)) does not hold if n is a random variable.
By Law of Total Variance, and letting E[X] = [itex]\mu[/itex] and Var[X] = [itex]\sigma^2[/itex],
Var[[itex]\sum_1^n[/itex] X] = E[Var[[itex]\sum_1^n[/itex] X|n]] + Var[E[[itex]\sum_1^n[/itex] X|n]] = E[Var[[itex]\sum_1^n[/itex] X]] + Var[n[itex]\mu[/itex]|n] = E[n[itex]\sigma^2[/itex]] + 0 = [itex]\sigma^2[/itex]E[n].
Are you sure the terms highlighted are correct?
Shouldn't it read:
Var[E[[itex]\sum_1^n[/itex] X|n]] = Var[n[itex]\mu[/itex]] = Var[n][itex]\mu^2[/itex] ??
And therefore, as mathman has stated (var(sum)=sum(var)) does not hold when n is a random variable?
I agree with Jimmy.
I agree to the general proposition; in my previous post I was making an error: I wrote Var[E[sum|n]] = Var[n[itex]\mu[/itex]|n], which should have been Var[n[itex]\mu[/itex]].
As I thought about the problem, I came to realize the following two special cases.
First, if [itex]\mu[/itex] = 0 then the "complicated" formula (with the Var[n[itex]\mu[/itex]] term) reduces to the simple formula. For example, if the X's are distributed normally with mean 0, then there is no difference between the two formulas.
Second, the linear relationship E[[itex]\sum_1^n[/itex] X|n] = a + b n, where a = 0 and b = [itex]\mu[/itex] implies:
Explained variance/Total variance = Var[E[[itex]\sum_1^n[/itex] X|n]]/Var[[itex]\sum_1^n[/itex] X] = Corr[[itex]\sum_1^n[/itex] X, n]2 or Var[E[[itex]\sum_1^n[/itex] X|n]] = Corr[[itex]\sum_1^n[/itex] X, n]2 Var[[itex]\sum_1^n[/itex] X] ... ... ... ... ... ... ... ... ... [Eq. 1],
which implies that the degree to which that the simple formula differs from the complicated formula is an empirical question. If it so happens that the correlation between the sum of X's and n is not significantly different from zero, then the two formulas will produce practically an identical result.
Here is a neat point, though: one can look at the equation [itex]\sum_1^n[/itex] X = [itex]\alpha[/itex] + [itex]\beta[/itex]n + [itex]\epsilon[/itex] as a least squares regression, where E[itex]\alpha[/itex] = 0, E[itex]\beta[/itex] = [itex]\mu[/itex] and E[itex]\epsilon[/itex] = 0. Remember that the least squares estimator [itex]\beta[/itex] of b in Y = a + bZ is [itex]\beta[/itex] = Cov(Y,Z)/Var[Z]. By letting Y = [itex]\sum_1^n[/itex] X and Z = n, one has [itex]\beta[/itex] = Cov([itex]\sum_1^n[/itex] X, n)/Var[n]. But E[itex]\beta[/itex] = [itex]\mu[/itex], so when Var[n] is given, there is a direct relationship between the Cov term and [itex]\mu[/itex], the mean of each X. And since Corr(Y,Z) = Cov(Y,Z)/([itex]\sigma_Y\sigma_Z[/itex]), there is a direct relationship between Corr[[itex]\sum_1^n[/itex] X, n] and [itex]\mu[/itex].
With a little computer programming, one can verify that when the X's are i.i.d. Normal[0,1], Corr[[itex]\sum_1^n[/itex] X, n] ---> 0 as expected (because [itex]\mu[/itex] = 0, the linear relationship implies zero correlation: b = [itex]\mu[/itex] = 0 and the [unbiased] least squares estimator of b = [itex]\beta[/itex] = 0; therefore the correlation has to be zero).
The intuition is that if the X's are sampled equally on both sides of the origin, then the number of X's being summed up does not change the expected value of the sum (= zero). Therefore the correlation between the sum and n is zero. Even neater, if [itex]\mu\approx[/itex] 0, then Cov [itex]\approx[/itex] 0, i.e. the simple relationship can be a good approximation even when [itex]\mu[/itex] isn't identically zero. The approximation worsens as [itex]\mu[/itex] gets farther away from zero. Which is a roundabout way of saying that Var[n[itex]\mu[/itex]] [itex]\approx[/itex] 0 if [itex]\mu\approx[/itex] 0.
hello people,
this is sofie.
i was wondering how jimmy1 got the result:
var(\sum_{i=1}^{N})=E(N)var(X) + var(N)(E(X))^2 using the law of total variance.
hope someone can tell me,
thanks!
I'm confused because you all use the notation n for both the random variable N and for the value of this N.
I get E(nVar(X1))+(E(X1))^2Var(n) and I don't know how that is the same as when n would be replaced by N.
  • · Replies 42 ·
