Solving Series-Connected Cells & AWG 18 Wire Circuit
The discussion revolves around a homework problem involving a series-connected battery made of six cells, the use of AWG 18 wire, and an indicator lamp acting as a resistor. Participants explore calculations related to voltage, current, resistance, and voltage drops in the circuit.
  • Homework-related
  • Some participants confirm the total voltage supplied by the battery is 9 volts, while noting that the actual current supplied may differ from the rated 1 amp due to the load and wire resistance.
  • One participant suggests using Ohm's law (V = I R) to calculate the voltage drop across the wire and lamp, emphasizing the need to consider the total resistance in the circuit.
  • Another participant provides a specific resistance value for AWG 18 wire, stating it is approximately 0.006384 ohms per foot, leading to a total resistance calculation for the 600ft of wire.
  • Concerns are raised about arithmetic errors in earlier calculations, with a specific example of a miscalculation being pointed out and corrected by a later reply.
Participants generally agree on the total voltage supplied by the battery but express differing views on the actual current supplied and the resistance of the wire, leading to unresolved calculations regarding voltage drops.
Participants reference specific resistance values for AWG 18 wire that may vary slightly depending on the source. There is also a noted arithmetic error in earlier calculations that could affect the final answers.
Lhawx
1. Homework Statement [
Six cells are connected in series to form a battery. Each cell has a rating of 1.5 volts and 1 amp. AWG 18-gauge wire joins the positive terminal of the battery formed by the series of cells to an indicator lamp 300ft away. Another 300ft length of AWG 18 wire runs from the lamp back to the battery's negative pole. The lamp acts as a 50 ohm resistor.
a. What are the total voltage and amperage supplied by the battery?
1.5 + 1.5 +1.5 + 1.5 + 1.5 + 1.5 = 9 volts.
Since the cells are connected in series, the amps would remain the same at 1 amp and 9 volts
b. What is the total resistance resulting from the 600ft of AWG 18 wire?
6.
5100 ohms x .6 = 30.906 ohms
c. What is the voltage drop across the total length of wire?
6.
I do not remember how to calculate!
d. What is the voltage drop across the indicator lamp?
6.
I do not know how to calculate this!
I know this is long but could someone please check this for me?
Thanks
Lisa
Your voltage and current reasoning is correct.
I don't know the wire standard off-hand but I assume you got the number correct.
For the voltage drop it's just Ohm's law, V = I R
Draw the wire, bulb and return wire as three resistors.
The total voltage drop across them must equal the voltage of the battery.
You can then work out the current through the total resistance and so the voltage drop across each.
Note that the 1Amp label on the cells is the maximum it can supply - it does not mean 1A is necessarily flowing in the circuit,
You got the voltage right. But the amperage actually supplied will most likely be different that the 1 amp rating, which is the amperage the battery is CAPABLE of supplying. How much it ACTUALLY supplies will depend on the load, which in this case is a lamp plus some resistance in the wire. You will have to work out the next two parts of the problem to find the amperage supplied to the load.
You must look up the resistance per foot of 18 gauge wire from a handbook or the web.
The relevant number is .006384 ohms/foot (you may find slightly different values; don't worry about this. Just use the number you find, or the number I've given). Since you have a total of 600 feet of wire, the resistance of the wire is .006384 * 600 = 3.83 ohms.
The lamp has a resistance of 50 ohms, so the total resistance of the load on the battery is 50 + 3.83 = 53.83 ohms. This means the current drawn from the battery is 9 volts / 53.83 ohms = .1672 amps. The current of .1672 amps is present in the full length of wire, so the voltage drop across the total length of wire will be the current in the wire times the resistance of the total length of wire: Vdrop = .1672 * 3.83 = .64 volts.
You need to be more careful with your arithmetic. Above you gave as a sample of your work:
"6.3. The Attempt at a Solution
5100 ohms x .6 = 30.906 ohms"
5100 x .6 does not equal 30.906; it equals 3060. Be careful. There's no sense in losing points for such a mistake in this the age of electronic calculators!
Thanks a lot for the help.
This was a mistype "5100 ohms x .6 = 30.906 ohms"
It should have been " 6.5100 ohms * .6 = 3.906 ohms
  • · Replies 105 ·
14K
