| Thread Closed |
Radio transmitter and Receiver |
Share Thread |
| Jan8-08, 07:00 PM | #1 |
How can I use radio wave to turn on/off a siren? I think it is possible for me to design a radio signal through this schematic:
http://www.aaroncake.net/circuits/fmtrans.htm The problem is, how do I design a receiver that can switch on a siren by receiving the radio signal? |
| Jan9-08, 12:07 PM | #2 |
Mentor
You could use a cheap radio receiver, and just bandpass the audio output to look for the tone frequency that you would be transmitting.
The circuit you show is for a typical low-power, unlicensed radio transmitter. The range of these transmitters is about 10m-20m, so don't expect too much. You also have to tune them to an open station frequency, so if you are in a highly-populated area with lots of FM radio stations, you will have trouble finding an open frequency. You might consider using an IR link instead of FM. You could start with a kit, like the one in the lower right corner of this page: http://www.transeltech.com/kits/kits1.html |
| Jan9-08, 07:18 PM | #3 |
Try using a garage door opener system.
Two reasons. 1-you need a transmitter on a set frequency that trans mits a code 2-you need a receiver that receives a set frequency that needs a code to turn the power on. Instead of the door opening and closing you could have the sireen latch on or off and the security of any hacker reduced. good luck |
| May21-08, 11:48 AM | #4 |
you would get ready wireless modules from Link Technologies they make ready modules you can further connect a buffer relay to switch on / off the siren
Rick |
| Thread Closed |
Similar discussions for: Radio transmitter and Receiver
| A transmitter and a receiver | Introductory Physics Homework | 6 | ||
| Wireless Transmitter/Receiver | Electrical Engineering | 3 | ||
| InfraRed Transmitter -> Receiver | Electrical Engineering | 1 | ||
| Why cant u make radio transmitter that transmit visible light instead of radio waves? | Introductory Physics Homework | 1 | ||
| AM Transmitter and Receiver Circut | Electrical Engineering | 2 | ||
