Digital read out of air pressure over time
The discussion revolves around the need for a system to monitor and log air pressure readings (approximately 200 psi) over a short duration (less than 5 minutes). Participants explore various data logging solutions, pressure testing setups, and compressor options for a specific application involving pressure testing of cylinders.
  • Experimental/applied
  • One participant seeks information on data loggers that can monitor air pressure and output data for later use in Excel.
  • Another participant suggests that a "data logger" or "data bucket" could meet the requirements, providing links to specific products.
  • A participant describes a planned setup involving multiple cylinders, a manifold, and the need for accurate pressure readings to detect leaks visually.
  • Concerns are raised about the accuracy of pressure readings in relation to the size of the cylinders being tested.
  • Participants discuss the feasibility of using multiple pressure sensors and data loggers to capture readings from several cylinders simultaneously.
  • Suggestions for compressors capable of reaching 225 psi are offered, including the use of compressed air cylinders as an alternative to traditional compressors.
  • There is a discussion about the safety and suitability of using compressed air, particularly in relation to potential oil contamination from machining processes.
  • One participant inquires about the equations needed to calculate the duration a compressed air supply can fill a cylinder to a specified pressure.
Participants express various opinions on the best approach to achieve the desired pressure testing setup, with no clear consensus on the optimal data logging solution or compressor type. Multiple competing views on the use of data loggers, compressors, and the implications of using compressed air are present.
Limitations include the dependence on specific definitions of pressure testing accuracy, the need for precise equipment, and the unresolved mathematical calculations regarding air supply duration and pressure relationships.
This discussion may be useful for individuals involved in experimental physics, engineering applications, or anyone needing to monitor and log air pressure in a controlled testing environment.
dingpud
I am trying to get some information to see if there exists a sub-system which can monitor air pressure (~200 psi) over a certain amount of time (less than 5 min.) and can output the readings so the information can be input real time or saved to a file which can later be input to Excel.
Anybody having any information would be helpful (background info, experience, web links, etc.)
Thanks,
-pud-
A common term for what you are looking for is called a "data bucket" or "data logger."They are used for different types of sensors, not just pressure transducers. Depending on the model, they are stand alone and receive a certain number of inputs that you select the intervals at which they sample. They have some amount of on board storage.
http://us.fluke.com/usen/products/Hydra.htm?catalog_name=FlukeUnitedStates
http://www.daytronic.com/products/MP/MPINTRO.htm
Thank you...
This is definitely what I was looking for. I really appreciate those links. I'll will have more questions soon.
Thanks again
my upcomming test...
OK, here is what I'm planning on doing...
I have some cylinders...OK, a butt load of cylinders which need to be pressure tested to about 225 psi each for under 5 minutes each. The plan is to develop a manifold that each cylinder is attached to. The manifold will provide the air supply. I'll have a pressure reading at each canister...thinking I might be able to test 5 or more at a time. The air supply (no not the group; hee hee) is going to be removed once the pressure is added to the cylinder. The test takes place as a visual under water...obviously looking for bubbles... I want to be a little more scientific about it and have the pressure readings captured, hence the data logger, and recorded every second with some accuracy. That way, in the event the operator doesn't see any bubbles, they can see a pressure drop at some point. Being that the air source is removed, any change or drop in pressure should be seen.
With the data logger, is there a way that i can be recording 5 or more different pressure readings? If so great. If not, any suggestions?
Also, any suggestions on a compressor that will get up to 225 psi? Is the more economical choice using a basic compressor, then "re-compressing" the air as in those air booster things?
Any help suggestions or ideas are always welcome.
Thanks
pud
How big are the cylinders? this will effect the size of the air compressor you need.
If they are failry small then either a scuba tank or an air brush compressor will be fine.
Depending on how large the cylinders are the pressure test might be a lot less accurate than the bubble test.
Imaging something the size of a scuba cylinder, these contain 80 litres of air at atmospheric pressure so the change in internal pressure from them losing a small 0.1cc air bubble would be an almost undetectable change in pressure. For a smaller cylinder the pressure change is easier to detect.
To test 5 at a timeyou would need 5 valves to separately seal each cylinder and you would need 5 sensors and a 5 channel logger.
These guys rule: http://www.onsetcomp.com/
I've never used one of their pressure gages, but they have 4 channel loggers for about $115 and gage or dp sensors for $190 each. You're unlikely to find anything that can compete with that. The 4-channel logger with 4 temperature probes is what I used here: https://www.physicsforums.com/showthread.php?t=205920&page=2
That Pico logger looks similar to the HOBO, but it looks like it has no memory - works only with a PC. But it has 11 channels as opposed to the HOBO's 4. And it's $185, which is pretty good. For the sampling rate, is 20 "kS/s" 20,000 samples/sec? I'm actually thinking of an application where I could use something like that at home...
Thanks for all of the responses...
The volume of the cylinder is ~ 1 cubic inch. The visual check is definitely going to happen, but I want to log all of this automatically as well.
Omega seems to have some neat stuff as well.
http://www.omega.com/ppt/pptsc.asp?ref=OM-CP-PRTEMP1000&Nav=dase01
It seems like they have a specific data logger for just for pressure applications, up to 500 psi within 0.05 psia. That should be plenty accurate for this test. EXPENSIVE though, so the previous thread's suggestion may make more sense.
Another question that I wanted to post, was what are everyone's thoughts on a compressor or "system" that will allow me to safely reach the 200 (+25) psi range that I am going to need for the test? Other than what a basic Goggle search has turned up, I'm not sure what else is out there.
Again, I appreciate everyone's help and input.
Thanks,
pud
With such a small volume for the cylinders, one thing you may want to look at in stead of a compressor is using compressed air cylinders. A large K type bottle with 2200 psi source pressure would handle quite a few of your bottles before you needed to swap it out for a new one. It would be pretty inexpensive and quiet. The only thing you would need is a precision regulator to knock down the pressure to your test point and a way to slow down the time to pressurize your bottles, i.e. an orifice. It's an option to consider.
Definitely going to be considered. someone outside of the "forums" environment suggested something similar to that as well.
Oops, just noticed that I said I did a Goggle search when it was actually a Google search...
It looks like the large tank for a supply, then regulated down to a usable pressure is the way to go. Will any inert gas work? Can you rent cylinders of plain old air? I'll try and post a picture of the apparatus when constructed.
You can rent compressed air. They will usually break it down into breathable air and industrial air (which may have a slight oil or other contaminant amount). I guess as long as you are looking at just the pressure, anything that creates that pressure is going to be OK. I don't think you'll beat the price of compressed air though.
Based on your setup you should not need an inert gas. The only caveat with using compressed air (a non-inert gas) is if you have a high pressure that comes into contact with a hydrocarbon (i.e. grease). Shouldn't be an issue for you, just something to keep in mind in case you ever run across it.
CS
Well, there is always a chance that these could come into contact with a small amount / residue of oil since we are machining the canisters. Will compressed air still be OK?
Yes, just don't use compressed oxygen!
Normal compressed air usually has some oil contamination anyway ( you pay a lot more for clean oil-free breathable air ).
Can't seem to recall the set of equations used to figure how how long I can use a supply at a certain volume and pressure to fill a certain volume and pressure.
Any suggestions
~2000psi in ~80ft^3 filling a can to ~200psi in ~1in^3
Just put everything in the same units then remember that at a fixed temperature, pressure * volume is constant.
Remember though when a cylinder is quoted as 80cu ft (eg standard Al scuba diving cylinder) that is the amount of air at atmospheric pressure that was put into it. It is not 80cu ft * 2000psi!
So 80 cu ft = 140,000 in^3 * 15psi, Fills a can of 1 in^3 at 200 psi
(140,000 * 15) / (1 * 200) = 10,000 times
Google gives much better search results in most cases...
This is pretty much what my dad and I came up with over the weekend. It matches, so typically that's a good thing.
good point about the atmospheric temperature thing though... thanks.
Yes, Google searches work better than Goggle searches...
I'll do my best to post whatever I end up coming up with for this thing. One thing that I did want to share with the "community" is that if you need to make a manifold for something carrying air, any other gas (most likely) or liquid, maybe, a good way is to take a chunk of aluminum and start drilling some holes. To start with the manifold for this project, I drilled a hole straight through, long ways, then drilled perpendicular holes which then entered the other hole. This allows me to plug in the air source, plug in a pressure guage, plug in a bleeder valve, etc. I can then have a bunch of outputs for the air, gas, or liquid to flow. By plug in I mean, tap the hole, then thread the thing in...or put a gasket around the hole, then clamp your part to it.
Well that's my cranial dump for the moment. Like I said, I'll try to post more when I can.
-pud-:biggrin:
Or you can save your time and simply purchase one to meet your needs. I routinely buy manifolds already manufactured in a number of configurations. A nice one that is large will run about $80. You can also buy square ones through McMaster-Carr.
http://www.dfburnham.com/pages2/manifold.shtml
Yeah, but you don't get your hands oily enough, nor do you get a chance to get those wonderful steel / aluminum splinters that way...:eek:
That is very true. There is a ton of fun to be had on a lathe and mill.
Are there instructions on how to post pics on this forum? If so, could someone please point me in the right direction, and I'll try and get a photo of what I've done so far.
Thanks
pud
Thanks
pud
When you post your message there is a little paper clip in the toolbar of the text editor. Click on it and you can upload your file.
CS
In these forums (engineering) you can't directly put a picture in your post. You can do that in the GD section though. The only thing you can do is attach a picture as Stewart pointed out.
Gotcha...
Yeah, those McMaster manifold look pretty nice. I should have figured that MC would have it...
I think they even sell Basketball rims/systems...
Long time, no report, but...I have another question...
I plan on using some Nitrogen tanks which will come with a pressure regulator from 2000 psi at the main source, down to the ~200 psi working range. Should I include an orifice to reduce the instantaneous pressure increase to the system? My volume, parts and plumbing included should be around 20-30 cubic inches. McMaster offers multiple types with the diameter being the scfm limiting factor. ANy suggestions on how much scfm I should use? 0.618 scfm @ 40 psi? 2.833 scfm @ 40 psi? I would like a steady increase, but do not want to waste time waiting for the system to pressurize...
Any help would be great...
  • · Replies 26 ·
  • · Replies 30 ·
16K
  • · Replies 0 ·
  • · Replies 19 ·
