| Thread Closed |
Calculating air drag |
Share Thread |
| Jan12-08, 01:00 PM | #1 |
I am unable to calculate air drag for a projectiles lab I am doing. It involves shooting elastic bands and measuring the distance they travel and compare it to the theoretical distance(with and without friction). It takes 0.45 seconds for the elastic band to fall and its initial velocity is dependent upon the stretch. I also have measured the mass(0.37grams) and the k value (31 N/m). 2. Relevant equations the equation 1/2 ACdrag p v^2 is only valid for teh initial drag force, but since the projectile loses velocity as time increases, how would i calculate the average drag force. (I also do not know the final velocity) 3. The attempt at a solution I have thought about integrating the graph Fdrag v.s V, however, I do not have the final velocity. |
| Jan12-08, 03:22 PM | #2 |
The average velocity is easy. It's just the change in position divided by the change in time. You'll need to do this for both the horizontal and vertical components of the motion. You can deduce the final velocity as follows. In Calculus I you would have learned that the average value [itex]f_{av}[/itex] of a function [itex]f[/itex] is given as follows.
[tex]f_{av}=\frac{1}{b-a}\int_a^bf(x)dx[/tex] Since you know [itex]f_{av}[/itex], as well as the integrand and the lower limit of integration, you can find the upper limit of integration (which in your case will be the final speed). |
| Thread Closed |
Similar discussions for: Calculating air drag
| Help with Drag. | Introductory Physics Homework | 3 | ||
| Calculating viscous drag in water | Mechanical Engineering | 2 | ||
| Calculating air drag for a massive rocket | General Physics | 6 | ||
| calculating drag | Engineering, Comp Sci, & Technology Homework | 5 | ||
| Calculating drag | Classical Physics | 3 | ||
