Why can't we see objects fall into a black hole?
The discussion revolves around the observation of objects falling into a black hole, specifically addressing why an observer would never see an object cross the event horizon. The scope includes theoretical implications of black hole physics and the nature of light and gravity in extreme conditions.
  • Some participants propose that due to intense gravity, time appears to stop for an observer not falling into the black hole, leading to the perception that objects never actually cross the event horizon.
  • Others argue that if an observer is falling into the black hole, they would not perceive the same phenomenon and would see the object fall past the event horizon.
  • A participant questions the idea that two objects falling into a black hole at different times would appear to occupy the same space from an outside observer's perspective, suggesting that the first object would slow down and stop before the event horizon.
  • Another participant clarifies that while it may seem that infalling objects "stop" as they approach the event horizon, their radial coordinate velocity approaches zero asymptotically, meaning they would always remain marginally in front of one another.
  • One participant emphasizes that light cannot escape a black hole, making it impossible to see an object after it crosses the event horizon, and likens the situation to a metaphor from "Alice in Wonderland."
Participants express differing views on the perception of objects falling into a black hole, with no consensus reached on the implications of these observations. The discussion remains unresolved regarding the interpretation of time and visibility in relation to the event horizon.
Limitations include the dependence on the observer's frame of reference and the complexities of light behavior near a black hole, which are not fully resolved in the discussion.
spizma
I read somewhere a while ago that if you were to look at an object falling into a black hole you would never see it actually fall past the event horizon, only continually approach it. That sounds very strange, is it true? If it is why so?
The intense gravity causes time from your frame of refenerence to appear to stop.
however this is only if you are not falling into the black hole as well, if you are then you won't see it stop.
Yes, if you are not initially falling 'into' the black hole, you will never. You will most likely orbit it :P
So then what happens if 2 objects fall into a black hole at separate time periods, by the objects view they would enter the black hole at separate times, but by an outside observer the first one would slow down and stop before the event horizon and then the second one would do the same.
So doesn't that mean we see 2 object occupying the same amount of space?
I think it's not quite correct to say that radially infalling objects appear to "stop" before they reach the event horizon, as viewed by an observer either orbiting a black hole (or being held stationary at some fix radial coordinate outside the hole). In the coordinates of such an observer, the time for an infalling object to reach the horizon is infinite and hence its radial coordinate velocity approaches zero asymptotically. One that was "in front" would however always stay marginally in front.
This may be loosely described as 'stopping' or 'freezing' in place, but I think that super-sensitive observations can always show relative movement.
Yes, that is correct.
I'm not sure why you think it sounds strange. Since light cannont escape a black hole, you couldn't possibly see the object after it went inside the event horizon. In fact, you can't see the event horizon either - which you can think of as light that is "trapped" in place. You can think of the light in the black hole as running the "Red Queen's race" from Alice in Wonderland - it is running as fast as it can, but it doesn't actually get anywhere.
As an object falls into a black hole and approaches the event horizon, it takes longer and longer for the light to escape. When the object reaches the event horizon, escape is impossible.
For more reading, you might try Ted Bunn's black hole faq:
http://cosmology.berkeley.edu/Education/BHfaq.html#q4
there are also some good sci.physics.faq entries on black holes.
  • · Replies 40 ·
  • · Replies 51 ·
  • · Replies 22 ·
  • · Replies 67 ·
  • · Replies 22 ·
  • · Replies 73 ·
  • · Replies 43 ·
  • · Replies 46 ·
10K
  • · Replies 51 ·
