What is the Electric Field Strength of a Single Photon?
  • Context: Graduate
  • Thread starter Thread starter linerz
    Photon
The discussion centers around the electric field strength associated with a single photon, exploring the theoretical implications and calculations involved. Participants examine concepts related to electromagnetic waves, quantum mechanics, and the nature of photons, with a focus on both theoretical and conceptual aspects.
  • One participant notes that the expectation value of the electric field for a single photon is zero, while the variance is non-zero.
  • Another participant argues that it does not make sense to attribute an intrinsic field to a photon, as photons are packets of energy and momentum.
  • A method for calculating the electric field strength of a single photon is proposed, involving the energy density of an electromagnetic wave and its relation to the energy of a photon.
  • Some participants challenge the validity of this method, stating that having a wave packet of finite length implies a spectrum of frequencies, complicating the definition of energy for a single photon.
  • There is a discussion about the nature of the electric field amplitude, with one participant clarifying that the oscillating nature of the electric field leads to a zero expectation value.
  • Concerns are raised regarding the assumption of a fixed number of photons in a coherent state, suggesting that it may not be appropriate to define an electric field per photon.
  • One participant suggests that semi-classical calculations can be used to estimate the average number of photons in a system, but emphasizes that this does not translate to a meaningful electric field strength per photon.
Participants express multiple competing views regarding the electric field strength of a single photon, with no consensus reached on the validity of proposed methods or interpretations.
Limitations include the dependence on definitions of photon states, the implications of wave packets containing a spectrum of frequencies, and unresolved mathematical steps in the proposed calculations.
linerz
Hi everyone,
I understand that a photon is interlinked packet of energy with oscillating electric and magnetic fields. My question is what is the electric field strength associated with a single photon? For a capacitor we of course use V/d and could use this to calculate the e-field of an atom (using the separation of the proton and electron for d), but what about the e-field of a photon so one can compare between the two?
Thanks,
L
Science news on Phys.org
The expectation value of the E field for a single photon (or, more generally, for ANY state with a well-defined number of photons; i.e number state) is zero.
However, the variance of the E field is non-zero.
Photons are packets of energy and momentum, it doesn't really make sense to say that a photon has an intrinsic field.
Claude.
The energy density of an EM wave = [tex]E^2/4\pi[/tex] in Gaussian notation.
Multiplying this by a reasonable length of the wave packet times a reasonable area for the wave front gives the energy in the EM wave. This energy equals hf for a single photon.
Using this, E for a single photon can be found.
No it can not. E (or, more correctly since it is QM, <E>) for a single photon is zero. It is NOT "undefined" or anything like that; it is just exactly zero; <n|E|n>=0
Any text about basic quantum optics will cover this.
Or, see e.g.
http://people.seas.harvard.edu/~jones/ap216/lectures/ls_3/ls3_u3/ls3_unit_3.html
Eq III-3A is the E-field operator; if you take the expectation value of this with respect to a number state (any state with a specfic number of photons, e.g. one) you always get zero.
I know this isn't exactly a pedagogical explanation; but unfortunately it is impossible to avoid math when dealing with photons; I don't think there is an "intuitive" explanation.
I think Pam is referring to the amplitude of E. Since E is oscillating its expectation value is zero.
There is a flaw in this method.
Having a wave-packet of finite length implies that the packet contains a spectrum of frequencies. It is therefore wrong to imply that you can define a specific energy for the photon. At best all you can do is define the width of the frequency spectrum.
Claude.
Claude.
That is the importance of the phrase "reasonable length".
For instance, if a ruby laser of a given power is pulsed on for 1 nanosecond,
the average amplitude of E per photon can be calculated.
That still doesn't make sense. An ordinary laser will not generate a Fock state (more likely a coherent state), so the number of photons is stricly speaking not fixed. Hence, there can't be an "E field per photon".
Of course it is always possible to use a semi-classical calculation if the power is high enough, e.g. just divide the energy with [itex]\hbar \omega[/itex]. That will give you a handle on the average number of photons in the system and is useful for e.g. looking at the thermal occupancy of states. However, for a single photon system this expectation value will be very,very small (much smaller than the fluctations) meaning it still doesn't make sense to talk about this in terms of the field per photon.
11K
  • · Replies 0 ·
  • · Replies 41 ·
  • · Replies 29 ·
