From one space dimension to two space dimensions in special relativity
The discussion revolves around the extension of Lorentz transformations from one spatial dimension to two spatial dimensions within the framework of special relativity. Participants explore various approaches to this extension, including the treatment of time and synchronization of clocks in different reference frames.
  • Some participants question whether simply adding y=y' is the best approach to extend Lorentz transformations to two dimensions.
  • One participant suggests that the transformation equations for time may not remain valid when moving from y=0 to y different from zero.
  • Another participant argues that the choice of y=0 is arbitrary and does not affect the physical situation, emphasizing that Lorentz contraction only applies in the direction of motion.
  • There is a proposal for an explanation via clock synchronization, suggesting that clocks with the same y' coordinates should display the same time due to their relative positions in the reference frame.
  • One participant presents a detailed scenario involving multiple clocks and light signals to illustrate synchronization, while questioning the implications for clocks at different x coordinates.
  • Another participant proposes that the Lorentz transformation should yield the same results when derived from both one-dimensional and two-dimensional scenarios, referencing the Michelson-Morley experiment.
  • There is a discussion about the implications of spatial coordinates, with an example involving moving rings to illustrate that y must equal y' from a spatial perspective.
Participants express multiple competing views on the best approach to extend Lorentz transformations to two dimensions. The discussion remains unresolved, with differing opinions on the validity of various methods and interpretations.
Some limitations include assumptions about clock synchronization and the dependence on the choice of reference frames. The discussion also highlights unresolved mathematical steps in deriving transformations across different dimensions.
This discussion may be of interest to those studying special relativity, particularly in the context of extending theoretical frameworks to higher dimensions and exploring the implications of clock synchronization in different reference frames.
bernhard.rothenstein
Consider that you have derived the Lorentz transformations in one space diomensions
x=g(x'+Vt')
t=g(t'+Vx'/c^2).
In order to extend the problem to two space dimensions many Authors add
y=y'.
Please tell me if that is the best approach.
Thanks.
??y= 0 is a purely arbitrary choice. Changing to y= any other value cannot change the physical situation at all.
The fact that y'= y (not y= 0) comes from the fact that the Lorentz contraction applies only in the direction of motion. Here x is chosen to be in the direction of motion.
two space dimensions SR
Thank you. Is there an explanation via clock synchronization i.e. is there a way to show that all the clocks C(x=const,y different) display the same time?
An informal explanation:
Your reference frame consists of all points that are stationary with respect to you. If an objects is moving with velocity v with respect to you we usually choose as a convenience an x-axis that is parallel to the velocity vector of the object (x') and a y-axis that is orthoganal to x. The y-axis in the moving frame (y') is orthoganal to the x' axis of the moving frame and parallel to your y axis. Since y' is parallel to y all points with the same y' coordinate in the moving frame (x' = constant) are the same distance from your y-axis and have the same velocity relative to your reference frame, so there is no reason that clocks with same y' coordinates should display different times.
lorentz transformation in two space dimensions
Thanks. Please have a look at the followings
Consider the clocks 1(0,0) and 2(x=rcosi,y=rsini) both at rest in I the first located at its origin O the second somewhere in the XOY plane. The first ticks whereas the second is stopped and fixed to display t=r/c. When 1 reads t=0 a light signal is emitted from O along a direction that makes an angle i with the positive direction of the OX axis. Let c(x)=ccosi be its projection on the OX axis. Arriving at the location of clock 2 the light signal starts it both clocks reading t=r/c. Let 3(x,y=0) be a clock located on the OX axis. It is synchronized by the OX component of the same light signal reading t=x/c(x).
Because t=r/c=rcosi/ccosi=x/c(x) the result is that after synchronization clocks 1 and 3 read the same running time and so
t'=g(t+Vx/c^2)
holds even for different values of y=y' as long as x is the same.
Please tell me is you find some flow there.
Because t=r/c=rcosi/ccosi=x/c(x) the result is that after synchronization clocks 1 and 3 read the same running time ...
That is one way of syncronising the clocks. Another way would be to preset clock 3 to x/c and have it started by the same omnidirectional signal that started clock 2 (which was preset to r/c). Certainly all 3 clocks would be showing the same running time in the rest frame, but so would any clocks (not having the same x coordinate) in the rest frame show the same running time. You have not shown why only the clocks with same x coordinate would appear to have the same running time to an observer moving relative to the clocks. For example clock 1 at the origin and clock 3 at some coordinate with x not equal to zero, would not show the same time in the moving reference frame.
and so t'=g(t+Vx/c^2) holds even for different values of y=y' as long as x is the same.
I think the best way to demonstrate that t' is independent of y is to derive the Lorentz transformation in one dimension and show that the same formulas are obtained when the Lorentz transformations are derived from a two dimensional situation such as the Michelson-Morley experiment.
It may also be worth noting that it is very easy to demonstrate that from a spatial point of view y must be equal to y'. Imagine two rings of the same radius moving on a common axis towards each other. If y did not equal y' then from the point of view of one moving observer, ring 1 may pass inside ring 2 while from the point of view of another observer with a different velocity ring 1 might pass outside ring 2. Clearly that cannot happen.
Hope that helps.
x=g(x'+Vt')
t=g(t'+Vx'/c^2).
y=y'.
Thanks.
Instead of x and x', it might be better to start with a fixed y-axis and a moving y'-axis (both axes are perpendicular to the direction of motion). Consider two meter sticks arranged parallel to y and y'. Let the moving meter stick (attached to y') travel past the stationary meter stick (attached to y) so that the ends are coincident as they pass. If the clocks along y and y' are synchronized in their respective frames, the moving and stationary observers must agree that the two coincident events (the passing at both ends) happened at the same time in each frame. Therefore, the moving and stationary meter sticks must be the same length.
This agreement now permits the moving and stationary observers to build light clocks along y and y' in the two frames that have the same mirror separation. With these clocks the transformation of time can be derived. Then, timing of events along the direction of motion can be used to derive the transformation between x and x'.
  • · Replies 53 ·
  • · Replies 20 ·
  • · Replies 146 ·
12K
