Can a Small Force Reverse the Direction of a Moving Train?
  • Context: Undergrad
  • Thread starter Thread starter rohanprabhu
    Direction Force Motion
The discussion centers on the application of Newton's 2nd law in the context of reversing the direction of a moving train weighing 1000 tonnes. It concludes that while a small force applied in the opposite direction can change the momentum, it will not instantly reverse the train's direction. Instead, a significant force or a prolonged application of a smaller force is necessary to achieve a reversal in direction. The key takeaway is that momentum must reach zero before a change in direction occurs, emphasizing the importance of force magnitude and duration in this scenario.
  • Understanding of Newton's 2nd law of motion
  • Basic concepts of momentum and force
  • Knowledge of frictional forces and their impact on motion
  • Familiarity with the concept of acceleration
  • Study the principles of momentum and impulse in physics
  • Learn about the effects of friction on moving objects
  • Explore the relationship between force, mass, and acceleration in detail
  • Investigate real-world applications of Newton's laws in engineering
This discussion is beneficial for physics students, educators, and anyone interested in understanding the dynamics of motion and force, particularly in mechanical systems like trains.
rohanprabhu
Newton's [itex]2^{nd}[/itex] law states that:
The rate of change of momentum of a body is proportional to the resultant force acting on the body and is in the same direction.
Let us assume that a train of 1000 tonnes is moving with a constant velocity [so, [itex]\frac{dp}{dt} = 0[/itex] (p = momentum)] on a rough surface in the [itex]\hat{i}[/itex] direction.
Now, i apply a small force, of a very small magnitude, in the [itex]- \hat{i}[/itex] direction i.e. in the opposite direction of the motion. Will it cause the train's direction to reverse? Here, the force applied by the engine is just enough to counteract the force due to friction. So, even a small force [which i can myself] apply on the train, can i reverse the direction of the train?
I'm asking this because it seems quite like a paradox to me. The 1000 tonnes figure is more or less for the perceptual impact :D.
The rate of change of the momentum would be the the -i direction (for as long as the force is applied), but the momentum itself would still be in the +i direction, until the momentum reaches zero. Therefore you would either need to apply a very large force, or apply a small force for a very long time to actually reverse the direction of the train.
While you may be making the net force on the train point in the opposite direction as its motion, that doesn't mean it'll instantly reverse direction. To change the large (let's say) positive velocity to a negative velocity will take a large acceleration or a small one for a long time (as nicksauce said).
  • · Replies 29 ·
  • · Replies 35 ·
  • · Replies 41 ·
  • · Replies 66 ·
  • · Replies 17 ·
