| New Reply |
inverter design |
Share Thread |
| Jan14-08, 05:35 AM | #1 |
inverter design
How to design 12vdc-220vac 2000,3000,5000 and 10000watts. I need a circuit diagrams and detailed discriptions.Thanks Ismail Dari.
| PhysOrg.com |
engineering news on PhysOrg.com >> Multiview 3-D photography made simple >> Giant 3-D printed bugs shed light on insect anatomy >> A microphone that listens with light |
| Jan14-08, 08:24 AM | #2 |
First of all is your input AC or DC. Or just ACDC!
The design procedures for the vaious power levels varies quite a bit and is not somehting you can get by just 'googling it' The filter part of the circuit itself involves a lot of things. I suggest you catch hold of some expert or find a book written by an expert (not just theory, but practical also) to help you out. |
| Jan14-08, 11:58 AM | #3 |
Mentor
We sure are getting a lot of questions about this lately. Ismail, please read this recent thread where we had a discussion about AC Mains safety:
http://www.physicsforums.com/showthread.php?t=112959 After reading that, could you please post a bit here about your background in electronics and project construction, and where the inverters will be used? Thanks. |
| Mar9-11, 10:46 AM | #4 |
inverter design
I am a new member i am working on one inverter but i am havering problems with connecting the emitters of the 2n3055 transistor to the negative terminal of the battery , can some help out with this plz . Thank you
| Mar9-11, 08:26 PM | #5 |
http://www.wbnoble.com/WN_articles/CD-ignition-SK.pdf Bob S |
| Mar14-11, 01:43 PM | #6 |
bob s thank you for your reply but the information you sent me did not hepl me with the solution but all the same i am greatful to you , but i will be happy if you can send me the origanal schemetic diagrame of a 12vdc to 240vac inverter 5oow, i have some other diagrams but they did not work at all, this is the information of what i am working on, i used 4047 ic to create the oscillation , LM324 IC sound chip for amplifing the oscillation wave for the base of the 2n3055 transistors and a ups transformer for amplifing the voltage, but i used 1ohm or 0.047 ohm but on the diagram i was to use o.1 ohm resistor to connect the emitters to the nagative terminal it is because i did not get 0.1 ohm, plz helpe to get the origanal information i will be more than greateful.
| New Reply |
Similar discussions for: inverter design
| 240 volt INVERTER | General Engineering | 1 | ||
| Question about inverter | Electrical Engineering | 3 | ||
| CMOS inverter | Engineering, Comp Sci, & Technology Homework | 0 | ||
| 555 DC AC inverter | Electrical Engineering | 0 | ||
| 1.5 HP compressor on a 400 W inverter | Electrical Engineering | 9 | ||
