Solve Permutation Group Homework Questions
  • Thread starter Thread starter jacobrhcp
    Groups Permutation
jacobrhcp
Hehe, I'm working through the complete groups books right now, so don't think I ask you all my homework questions... I'm doing a lot myself too =).
1) If H is a subgroup of S_n, and is not contained in A_n, show that precisely half of the elements in H are even permutations
2) show that for n>3, all elements of S_n, can be written as a product of two permutations, each of which has order 2.
1) If there is an element x that's not in A_n, then x=yz, where either y or z is odd.
call this element x'. x'=y'z', and either y' or z' is odd again.
If you continue this process, you eventually have to get back to x, because S_n is finite. If you can show this is when you repeated the process n/2 times, you're done... because the other half are the even ones you encountered when you wrote it as a product every time.
But this is a step I'm having problems with. And I realize this argument has loads of holes in it.
2) I have only a vague clue on this one. I thought I might write the element as a product of disjoint cyclic permutations. Now cyclic permutations are of order 2.
because this is grammatically close to what I want I thought it might help =P, but I really don't know how get from here to the point where you have two elements of order 2.
Cleaning up your argument:
If x is an odd element of H, then you can show that each coset of <x> has the same number of even and odd elements, but you can skip the middleman.
Let's say:
H=\{h_1,h_2...h_k\}
and x \in H is some odd permutation what can you say about
\{xh_1,xh_2...xh_k\}
relative to H?
For part 2:
Cyclic permutations aren't of order 2 - but they are all even permutations...
1) oh my. I've thought about it for quite some time before I realized. that set is again H, ofcourse. Because odd * odd=odd and odd * even=even, by symmetry it can only be that half the elements are odd. Thanks!
2) cyclic permutations are indeed not of order 2, but are they even? I'm not sure I get this. If you know this yourselves, can you help me a little bit further?
Sorry, I made a mistake -- cyclic permutations can be odd. Cycles of odd length are even.
The order of element of a group <x> is the number of elements in the group that is generated by x. (This group ends up looking like x^0,x^1...x^n if it is finite and ...x^{-1},x^{0},x^1... if it is infinite.) For elements of finite order, it is also the smallest exponent so that x^n is the identity.
An even permutation is a permutation that, can be written as the composition of an even number of transpositions. (http://en.wikipedia.org/wiki/Even_permutation).
You might consider the following as a warm-up for part 2:
Show that any cycle of length n can be decomposed into n-1 transpositions.
Show that any permutation can be written as the product of two permutations that are either the identity or have order 2.
