What is the velocity of a transverse wave on a steel cable under tension?
The velocity of a transverse wave on a steel cable under tension can be calculated using the formula velocity = sqrt(T/(m/L)), where T is the tension and m/L is the linear density. To find the linear density, one must first convert the density of steel (7860 kg/m³) into linear density by multiplying it with the cross-sectional area (2.79 * 10^-3 m²) of the cable. The tension provided is 1.00 * 10^4 N, which allows for the calculation of wave speed once the linear density is determined.
  • Understanding of wave mechanics and transverse waves
  • Familiarity with the concepts of tension and density
  • Knowledge of linear density calculations
  • Basic algebra for manipulating equations
  • Calculate linear density using the formula m/L = density * cross-sectional area
  • Apply the wave velocity formula with the calculated linear density
  • Explore the effects of tension on wave speed in different materials
  • Investigate the relationship between wave speed and material properties
Students studying physics, particularly those focusing on wave mechanics, as well as educators and anyone interested in the properties of materials under tension.
sheri1987
A steel cable, of cross-sectional area 2.79 * 10^-3 m2, is kept under a tension of 1.00 * 10^4 N. The density of steel is 7860 kg/m3 (this is not the linear density). At what speed does a transverse wave move along the cable?
velocity = sqroot(T/(m/L)) m/L = linear density
I have no idea where to start this because I do not know what to do with the area given and also how to convert the regular density to linear density. Can anyone start me off? i then would know how to solve the problem, thanks!
density =mass/volume and volume=Cross-sectional area*length
Helps?
thank you!
  • · Replies 19 ·
  • · Replies 26 ·
