E-field at the center of a semicircle
  • Thread starter Thread starter pcandrepair
    Center E-field
The problem involves calculating the electric field at the center of a semicircle formed by a uniformly charged insulating rod. The rod has a specified length and total charge, and participants are tasked with finding the electric field's magnitude at a designated point.
  • Participants discuss the calculation of the radius and the application of relevant equations, with some expressing confusion over the results obtained. There are suggestions to use integration to account for the contributions of small charge elements along the semicircle. Questions arise regarding the use of Gauss's law and its applicability to this scenario.
The discussion is ongoing, with various participants exploring different approaches to the problem. Some have provided insights into integrating the electric field contributions, while others question the assumptions made regarding symmetry and the direction of the electric field components. There is no clear consensus on the best method to proceed.
Some participants note that they have not yet studied Gauss's law, which may affect their ability to engage with certain suggestions. Additionally, there are discussions about the limits of integration and the interpretation of the semicircular geometry.
pcandrepair
[SOLVED] E-field at the center of a semicircle
Calculate E at center of semicircle:
A uniformly charged insulating rod of length L = 12 cm is bent into the shape of a semicircle as shown. The rod has a total charge of Q = -6 nC. Find the magnitude of the electric field at the point P -- the center of the semicircle. (Answer in units of N/C.)
E = K((Q)/(r^2))
To find the distance/radius from the point P to any point on the semicircle would be...
12cm*2 = circumference
2*pi*r = 24cm
r = 3.8197cm or .038197m
When I use the equation under the "relevant equations" heading, I'm getting a really huge (E) of about 36,970 N. This can't be right and I'm not sure of where to go from here. Any help would be greatly appreciated. Thanks!
E = K((Q)/(r^2))
2*pi*r = 24cm
try to use gauss law... div(E)=rho.
i suggest you spherical coordinates and divergence theorem..
bye
we haven't even started studying gauss law yet...
What you did would be correct if the electric field from each infinitely small piece of semicircle was in the same direction.
You need to integrate the field caused by each infinietly small piece of semicircle.
When I integrate the field of the semicircle, I come up with a field of magnitude -147,858 N/C...?
The electric field, [tex]d\textbf{E}[/tex], due to a small piece of charge, [tex]dQ[/tex], is
[tex]d\textbf{E}=\frac{kdQ}{r^2}(\cos\theta \textbf{i} + \sin\theta \textbf{j})[/tex].​
Since we obviously can't take the integral with respect to charge, let's define the linear charge density of the rod as
[tex]\lambda=\frac{Q}{L}[/tex].​
Now, being a density, we can also say, for a small length of the rod, [tex]dL[/tex], that
[tex]\lambda dL = dQ[/tex].​
Also, for a small angle, [tex]d\theta[/tex],
[tex]dL=rd\theta[/tex], so [tex]r\lambda d\theta = dQ[/tex].​
Plugging this in above, we have
[tex]d\textbf{E}=\frac{kr\lambda d\theta}{r^2}(\cos\theta \textbf{i} + \sin\theta \textbf{j}),[/tex]​
So, simplifying and including the integral sign,
[tex]\textbf{E}= \frac{k\lambda}{r} {\int^{\frac{3\pi}{2}}_{\frac{\pi}{2}} (\cos\theta\textbf{i} + \sin\theta\textbf{j})d\theta,[/tex]​
which I will leave to you to solve.
Thanks for your help, foxjwill!
You're very welcom. :)
I have the answer to an example problem of this type, but each time I calculate this my answer turns out to be different.
Since the j component is symmetrical, they cancel each other out, so I came up with
[tex]\textbf{E}= \frac{k\lambda}{r} {\int^{\frac{3\pi}{2}}_{\frac{\pi}{2}} (\cos\theta\textbf{i})d\theta,[/tex]
Solving for the integral, I get
[tex]\texbf{E}= \frac{k\lambda}{r} \left[\sin\theta\right]^{\frac{3\pi}{2}}_{\frac{\pi}{2}}[/tex]
[tex]\texbf{E}= \frac{k\lambda}{r} \left[\sin\frac{3\pi}{2}-\sin\frac{\pi}{2}\right][/tex]
-1 -1 is -2, so
[tex]\texbf{E}= \frac{k\lambda}{r} \left(-2\right)[/tex]
I'm sure my radius is fine, so where else am I going wrong?
-1 -1 is -2, so
I'm not entirely sure what you're asking. Were you given values?
bye
You know, this kind of response isn't very helpful. Can you really solve this problem this way? Gauss's law is convenient for problems with lots of symmetry so that the surface integral becomes trivial, but for a problem like this, I don't see how it would be easy to do, especially compared to simply integrating Coulomb's law, as above.
why is this true? [tex]dL=rd\theta[/tex] Maybe I am missing something here because this doesn't make sense to me...
It's the differential line element along the circumference of a circle. Arc length on a circular arc is angle (in radians) times radius; here r is radius and [tex]d\theta[/tex] is the (differential) angle.
I think that sometimes it helps people to give them just the hint and not all the calculus done by somebody else... Perhaps for me is very important to rember that using only 4 equations (Maxwell) and some calculus we can solve every C.E.M. problem.
I thought that just saying Gauss+div theorem he could recognize on which subset of (0,6.28) integrate...
i see more foundamental to rember where equations come from, and try every time to "derive" all the connections and then solve the problem... maybe not only analitically.
in any case i know that in this world is more important to give the right answer as soon as possible instead of thinking why??
As an example: The length of every line on a plane is [tex]L=\int dl=\int\sqrt{dx^2+dy^2}[/tex]
and only in this contest you have [tex]\int Rd\vartheta[/tex].
this after differentiating the trasformation of coordinates:
[tex]x=Rcos\vartheta; y=Rsin\vartheta[/tex]
regards marco
Marco_84: I agree, and I didn't mean to suggest that you were incorrect to suggest the use of Gauss's Law. My objection had to do with where you might lead the OP with this, since it is quite common in introductory courses to label certain problems as "Gauss's Law" problems when they involve symmetries that allow the reduction of the problem to a trivial one. Examples are those with spherical symmetry, linear symmetry, or planar symmetry, which allow one to make arguments for the integral over a suitably defined surface to be either zero-valued or equal to the field magnitude times the area (i.e. the field is either parallel to or normal to the surface). In such cases one need not even take any explicit integrals, since they all reduce trivially.
This problem doesn't quite fall into that category, IMO, so I wouldn't want the OP to struggle to define a surface with those characteristics; it would not be easy, and it's not necessary.
I guess we could agree to call the solution of this problem "explicit use of Gauss's Law" or something else to signify that one really has to do the integral. (?)
Why do you go from pi/2 to 3pi/2?
It doesn't matter what limits you pick, as long as the difference is pi, because it's a semicircle. Whether you go from zero to pi or pi/2 to 3pi/2 doesn't matter.
Perfect you get it... people reduce the differential equations to simpliest (already solved) finite quantities after a "smart" knowledge of the simmetries involved... but then we have to know how to simplify the integral knowing the meaning of what a flux is and so on..
This is what i would like to suggest people when ask.
best regards
m
14K
  • · Replies 21 ·
14K
  • · Replies 18 ·
36K
