LabView Opinion: Good and Bad Points & Widespread Use
  • Thread starter Thread starter lisab
The discussion centers around opinions on LabView, particularly its advantages and disadvantages for data acquisition in laboratory settings. Participants share their experiences and thoughts on its usability and prevalence in the field.
  • Exploratory, Technical explanation, Debate/contested
  • One participant seeks opinions on LabView's good and bad points, as well as its widespread use in laboratories.
  • Another participant expresses concern that LabView code often lacks sufficient explanation, making it difficult for others to modify later, a critique that could apply to programming in general.
  • A different participant notes that while LabView is very user-friendly, it may lead to complacency in programming practices, suggesting that ease of use could result in less rigorous experimental methods.
  • One participant mentions their lab's extensive use of LabView and expresses satisfaction with the software.
There is no clear consensus on LabView; participants express both positive and negative viewpoints, indicating a mix of satisfaction and concern regarding its use and coding practices.
Some concerns about code clarity and programming discipline are mentioned, but these points remain unresolved and depend on individual coding practices and experiences with LabView.
This discussion may be useful for individuals considering LabView for data acquisition, as well as those interested in programming practices within laboratory environments.
lisab
Staff Emeritus
I'd like to know this group's opinion on LabView. Our lab uses it and I have an opportunity to learn how to use it for data acquisition.
What are the good / bad points? Is it widely used?
I used to do a bit of programming (C, VB), but that was many years ago.
Technology news on Phys.org
The issue I have with it is that many programmers tend not to put enough expalaination in there codes to enable someone else to modify it later (but we can say that for all codes). My other issue is that it tends to look like spaghetti code when it gets long.
We use it extensively in our labs and am very happy with it.
Thanks!
Labview is fantastic, but it tends to make you lazy because it makes a lot of things so easy :). If you can afford it - use it! But, as noted above, don't let it make you a sloppy experimentalist.
  • · Replies 21 ·
