| Thread Closed |
What is quantum field theory? |
Share Thread | Thread Tools |
| Apr15-04, 09:04 PM | #1 |
The propagation of something, photon or particle, can have many possible paths, thus the Feynman path integral formulation of quantum mechanics. The initial position is relatively fixed and the final position is relatively fixed (compared to all of space). But it's path from beginning to end can be anything. So I wonder how far this concept goes. Does it apply to the first appearing of a particle (or particle creation)? Can the location itself of a particle's initial position when first formed also have many possible locations as well? Would this be quantum field theory? In otherwords, its intial state would be non-existence, its final state would be existence, and every possible path would be replaced with every possible location?
thanks. |
| Apr16-04, 03:21 AM | #2 |
Hi, a quantum field theory is like a classical field theory only the field is quantised into discrete chunks. The electromagnetic field for instance is quantised into photons.
| Apr16-04, 07:57 PM | #3 |
I'm trying to develop an intuitive understanding of QM, and why it might be necessary from more fundamental principles (if possible).
Yes, I know that QFT is derived by making observables into operators and all that. But that seems to only be a trick to make the data fit the curve. But it does not explain the nature of reality such that quantization should be necessary in the first place. So let me take a stab at it and see how far I get. Feynman's path integral formulation of quantum mechanics is valid where we must consider the possibility of every possible path from A to B, and the path integral considers the interference of every possible path from A to B which results in the most likely overall path from A to B. In ordinary QM, A and B are given (if I remember right). So when in second quantization, I suppose that even the initial and final states of A and B are the result of considering every possibility. Does this seem right? Also, just considering the words, "every possible path", seems to indicate some mathematical formulation that is valid for every possible path. This sounds a lot like a formulation that is invariant (symmetrical) with respect to all possible paths. So is QM a way of handling broken symmetry, where some formulation is symmetrical wrt every possible path, so that we are forced to consider every possible path, and the path integral gives us the most likely path, or in other words... how the symmetry is broken? Thanks. |
| Apr16-04, 09:01 PM | #4 |
Recognitions:
We usually think of symmetry at the level of the Hamiltonian or Lagrangian, not necessarily the amplitude.
Still it is of course there. For instance, you want your physical laws to be invariant under the poincare group, that is rotations, translational invariance, and boosts. Understand this, in most cases the number of different paths is infinite. In a sense our field is an infinite dimensional quantity, and is decidedly nonlocal. We also are dealing with something that needs to be covariant, different observers must agree on the results of any measurement done, once a frame has been picked. So it should be apparent that this amplitude we are looking at is something very abstracted from physical intuition. I don't like assigning to much meaning to the amplitude, or even the probability space. Its an aesthetic choice, but I prefer looking at real measurable observables (like laboratory frame cross sections) and giving that meaning. A. Zee gives a nice little picture of what a quantum field is, in his book. The Mattress picture, where particles are identified as excitations of the springs. He belabors the point, that it is a harmonic paradigm, and could in principle be generalized. |
| Apr17-04, 03:07 AM | #5 |
Hmm, if you don't understand why certain variables are quantised then you need to go back and relearn basic quantum mechanics before you can start doing Quantum Field Theory.
Remember the experimental evidence, photoelectric effect, blackbody radiation, all those experiments illustrate why certain quantities must be quantised. |
| Apr17-04, 09:52 AM | #6 |
I'm playing with the idea that the only thing we do know for an absolute certainty is that the universe exists. Anything beyond that must have probabilities associated with alternatives. We are working backwards to reverse engineer the universe from observables to principles. So first quantization uses Feynman's path integrals to produce a path from known position to known position. Second quantization produces particle position from fields of known initial to final states. So I suppose third quantization would produce fields from various possible configurations of spacetime. But perhaps this gives us a clue as to the nature of reality. If all that is knowable for certain is that the universe exists and all else must consider probabilities of alternatives, then perhaps the nature of spacetime itself is derived from every possible alternative. Perhaps the overall size and acceleration of the universe is derived from every possible time of creation and acceleration speed. |
| Apr17-04, 10:01 AM | #7 |
| Apr17-04, 10:22 AM | #8 |
That is pseudo-science, or at most philosophical gibberish.
Scientists do not explain things from first principles, they observe the world and describe those observations using mathematical laws. |
| Apr17-04, 04:14 PM | #9 |
But to suggest that it is impossible to derive physics from logic is to say that reality is fundamentally not understandable. It is in other words to suggest that the universe is a logical absurdity. But if the universe is not a logical absurdity, then prove that it is not. And the only way to prove that the universe is not a logical absurdity is to derive physic from logic alone. Simply deriving a theory for the existence of something on the basis of smaller somethings is just begging the question as to where the smaller somethings came from. |
| Apr17-04, 04:40 PM | #10 |
Ok then, we curve fit. But we get physical laws that make sense. If you are not happy with it philosophically then er I don't really care.
| Apr17-04, 05:37 PM | #11 |
Mentor
It appears that all of our physics ARE essentially built on accepted postulates and phenomenology and not "derived". However, I disagree with your assertions that these are merely "curve fitting". Zz. |
| Apr17-04, 06:58 PM | #12 |
| Apr17-04, 07:04 PM | #13 |
Mentor
Zz. |
| Apr17-04, 08:27 PM | #14 |
I for one will not deny the premise of science, so I will assert that the universe is totally logical, which precisely means that physics can be derived from logic. |
| Apr17-04, 10:49 PM | #15 |
Logic is a model of human reasoning, not of the universe.
How can the universe be logical? |
| Apr18-04, 08:08 AM | #16 |
| Apr18-04, 08:11 AM | #17 |
Mentor
There is a difference between DERIVING our observations via ab initio/First Principles calculations, and logically deriving results/observations/consequences based on postulates. You will notice that practically ALL of physics today is based on the latter. You are confusing the latter with the former. SR's postulates were never "derived". However, all consequences based on those postulates ARE logically derived! There is a difference! Notice that in none of my previous postings in this string that I complete eliminate any possibility that we can obtain our knowledge of the physical world via other ways (logic?). I simply asked you for one clear example where this is possible. Since you can't, my whole point then is that what you are doing is nothing more than speculating, since you have zero physical evidence to based your opinion on. Now, is this not a logical conclusion also? Zz. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: What is quantum field theory?
| Quantum Field Theory | Quantum Physics | 53 | ||
| [SOLVED] Quantum Field Theory: Field Operators and Lorentz invariance | Quantum Physics | 6 | ||
| Is quantum field theory a genuine quantum theory? | Quantum Physics | 3 | ||
| ANN: quantum field theory course. | Quantum Physics | 10 | ||
| Two concepts about quantum electrodynamics and quantum field theory | Quantum Physics | 16 | ||
