| New Reply |
blackholes and expanding universe |
Share Thread | Thread Tools |
| Jan16-08, 11:57 PM | #1 |
Dear all,
i'm very new to cosmology/astronomy branches of physics. i've one simple question. it's known that the universe is expanding and i suppose the measurement was made by hubble for which he won the nobel prize. but also, i recently learnt that there're blackholes at the centre of galaxies like milky way. if that's true, the blackholes shud be 'sucking' in the other celestial bodies, wont they? in this case, considering there are many blackholes spread across the universe, isnt it cotradictory to the fact of 'expanding universe' ? could someone explain? thanks. |
| Jan17-08, 04:28 PM | #2 |
Recognitions:
Blackholes at galaxy centers are sucking in nearby matter. There is no contradiction to the universe expansion, since that is an expansion of space, observable between galaxies. The black hole gravity falls off by the inverse square law, so its sucking is only on objects that are closeby within the galaxy.
| Jan21-08, 11:30 PM | #3 |
Edwin Hubble was not awarded a Nobel Prize for his discovery of the expansion of the universe. By the time Nobel community realised that astronomy was a branch of physics it was too late. |
| Jan22-08, 03:52 AM | #4 |
blackholes and expanding universemay be they were wrong.. |
| Jan22-08, 07:58 AM | #5 |
You should see this.
The following site quotes: 'While Hubble never did win the Nobel Prize (there was no category for astronomy at the time), his legacy reaches far beyond such temporal tokens of recognition. Stephen Hawking, noted cosmologist and author of A Brief History of Time, has hailed Hubble's expanding-universe discovery as "one of the great intellectual revolutions in the twentieth century." ' http://www.exploratorium.edu/hubble/people/edwin.html. |
| Jan25-08, 10:35 AM | #6 |
The reason black holes are not sucking in all the planets is because of a boundary known as the event horizon, it's the point towards a black hole where there is no chance of possible escape. Any matter outside of the event horizon is not affected.
Think of the event horizon as a shadow, anything outside of the shadow is mainly unaffected. By unaffected though I mean they are not inevitably sucked into the black hole, however due to the mass of a black hole it still has gravitational effects even on objects outside of the event horizon, which is why some are orbited by solar systems and such. For more information read chapters 6 and 7 within Steven Hawking's book A Brief History of Time. |
| Jan29-08, 03:36 PM | #7 |
It's only the 'Observable' universe that has been observed to be expanding. But it has been observed to be doing several other things too, and if you put them all together you get the same conditions undergone by a 'package' of air on its way into a Vacuum Cleaner. Just going by the 'Physics' of the matter. It's not my intention to harm or upset anybody. |
| Jan29-08, 05:46 PM | #8 |
Hi folks,
There seems to be a misconception in this discussion. Supermassive black holes in galactic centers are very concentrated gravitational bodies, but they are no Godzillas sucking in everything in the Galaxy. For example, Sagittarius A*, the supermassive black hole at the center of the Milky Way, has an estimated mass of 3.6 million solar masses, and a diameter of 20 million kms, about equivalent size to the orbit of Venus. I read somewhere (I forget where), that black holes in (non-active) galactic centers like ours are estimated to suck in less than 1 star per year on average. (Don't hold me to an exact number). By comparison, there are about 3.6 million stars concentrated in our galactic center within a 1 parsec radius from Sagittarius A*. The central part of our galaxy has a radius of about 10 parsecs, and its crowded with stars. Inside 1 parsec, each star actually orbits Sgr A*, as if they were the only two objects in the gravitational system. Here's a paragraph from the Black Hole Encyclopedia online: "From a distance, a black hole's gravitational pull is no different from that of any other star or other object of the same mass. If our Sun were suddenly replaced with a black hole of the same mass, for example, there would be no change in Earth's orbit -- the planet would not be "sucked in" by the black hole. A black hole's surface gravity is stronger than that of a normal star because all of its mass has been squeezed into an almost infinitely small point. But from comparable distances in space, if you judged by gravitational pull alone, you couldn't tell the difference between a black hole and any other object of the same mass." Also, a black hole's event horizon does not in any way inhibit the infall of objects or radiation. Once something has fallen inside, the super-high gravity extending out to the radius of the event horizon simply prevents it from getting back out. The largest known supermassive black hole is in the M84 galaxy. It is estimated at 1.5 billion solar masses and has a diameter equal to Neptune's orbit. Oops, M87's black hole is estimated at 3B solar masses, and a diameter larger than Uranus'. Jon |
| Jan31-08, 06:37 AM | #9 |
| Jan21-12, 01:49 PM | #10 |
The black holes at the centers of galaxies suck in matter around them while those black holes move away from each other due to the expansion of the universe. These two phenomena happen simultaneously. They have a negligible effect on each other because of the difference in scale. The expansion of the universe is a much larger and slower phenomenon than the effects of individual black holes.
| Jan21-12, 06:35 PM | #11 |
| Jan29-12, 04:11 PM | #12 |
As far as i know;
- Even if it is a black hole, the gravitational force decrease exponentially as the distance increases.. Well maybe can affect matter in another galaxy, as much as an electron affects our planet by its gravitational force. - You can think of the dark matter as the web the galaxies are placed onto.. Its actually what really kept the expansion of the universe at bay so far, but Nobel Prize winners proved that this web has failed. And the universe is doomed to expand until everything freezes in Absolute Cold - The doom of our universe is the Dark Energy. It expands space, and with the failure of the Dark Matter, keeping this force at bay by its gravitational affects up until five billion years ago. The dark energy has won, and thus Hubble made his discovery of the expanding universe.. This caused Einstein to call his constant, his biggest blunder. I find it funny he ever said that, he almost sounds like he miscalculated something at the creation of this universe and failed to create a static universe.. Well, his biggest blunder(as he puts it) is a nobel winning discovery now. Go figure... |
| Jan30-12, 03:33 PM | #13 |
Recognitions:
| Jan31-12, 05:01 AM | #14 |
| Jan31-12, 01:36 PM | #15 |
| Jan31-12, 03:48 PM | #16 |
| Feb7-12, 12:52 AM | #17 |
| New Reply |
| Thread Tools | |
Similar Threads for: blackholes and expanding universe
| Expanding universe... expanding atoms | Cosmology | 19 | ||
| Is the whole Universe expanding, or just the Observable Universe? | Cosmology | 4 | ||
| expanding people in an expanding universe? | Special & General Relativity | 36 | ||
| expanding people in an expanding universe? | General Astronomy | 7 | ||
