Can you prove that two sequences with a specific feature have the same limit?
  • Context: Graduate
  • Thread starter Thread starter sutupidmath
    Proof Sequences
The discussion revolves around proving that two sequences, \( (a_n) \) and \( (b_n) \), which satisfy the condition \( a_n < b_n \) for all \( n \) and have specific relationships between their terms, converge to the same limit. Participants explore various approaches to establish this limit equality, focusing on the definitions of limits and properties of monotonic sequences.
  • One participant proposes to assume that the limits of the sequences are different and derives contradictions based on the definitions of limits.
  • Another participant notes that both sequences are strictly monotonically increasing and suggests that this property guarantees the existence of limits.
  • Some participants discuss the implications of one limit being infinity and how that affects the proof.
  • There is a suggestion to consider the effect of removing a finite number of terms from the sequences on their limits.
  • One participant expresses confusion about how to apply the hints provided and seeks further clarification on using epsilon-delta proofs.
  • Another participant emphasizes that the approach of removing terms is a well-known theorem and invites others to provide a formal proof of this theorem.
  • There is a discussion about the rigor of different approaches, with some preferring a more formal epsilon-delta proof while others advocate for intuitive reasoning.
Participants do not reach a consensus on the best approach to prove the limit equality. There are multiple competing views on how to proceed with the proof, and some participants express uncertainty about the implications of the hints provided.
Limitations include the dependence on the assumption that the sequences are strictly increasing and the unresolved nature of the mathematical steps involved in the proof. The discussion also highlights the potential complexity when considering cases where limits may approach infinity.
sutupidmath
Sequences, need help!
Well there is this problem that i am struggling to proof, i think i am close but nope nothing yet. Well, the problem goes like this:
We have two sequences [tex]\ {(a_n)}[/tex] and [tex]({b_n})[/tex], whith the feature that [tex]{a_n}<{b_n}[/tex] for every n. Also, [tex]{a_2}={b_1}, {a_3}={b_2}...[/tex] and so forth. What i need to show is that they have the same limit, that is:
[tex]\lim_{n\rightarrow infinit} {a_n}=m=\lim_{n\rightarrow infinit} {b_n}[/tex]
I started by using the definition of the limit like this,
First i assumed that the limits are not the same so i put:
[tex]\lim_{n\rightarrow infinit} {a_n}=a[/tex] and [tex]\lim_{n\rightarrow infinit} {b_n}=b[/tex], where a is not equal to b, so it must be either smaller or bigger than it.
For every epsilon, there exists some number N_1, that for every n>N it is valid that:
I a_n-a I< epsylon, and also for every epsylon there must exist some number call it N_2, that for every n>N_2 we have:
I b_n- b I< epsylon,
then i took N=max{N_1,N_2} so for n>N, both
I b_n- b I< epsylon and I a_n-a I< epsylon are valid
then after some transformations i got:
a- epsylon<a_n< a+ epsylon and
b-epsylon< b_n < b+ epsylon
let us now suppose that b<a, than this is not possible since from a theorem i could find a number call it n_o that for every n>n_o also b_n<b<a_n , which actually contradicts the very first supposition that b_n>a_n.
now let us take b>a, and also from the supposition that b_n>a_n whe have
a-epsylon<a_n<b_n<b+epsylon
and this is where i get stuck.
Any suggestions would be really appreciated.
, so from here we have that the limit of a_n would be both b and
dear suputidmath
first observe that both a_n and b_n are strictly monoton increasing sequences. You can prove that every strictly monoton increasing sequence has a limit
(there are two cases: the sequence is bounded or it is not).
Take care that you cannot argue as you did if the limit a = infinity! infinity -epsilon < a_n makes no sense!
When proving that a=b the case one is a real number and the other is infinity is simple.
Now asume that both a and b are different real numbers.
let d=abs(a-b).
you know since a_n converges every epsilon neighbourhood of a contains almost all a_n (the same holds with respect to b and b_n). Have a look at the epsilon=d/3 and derive a contradiction.
You could also use the fact that taking away a finite number of terms does not effect the limit of the sequence.
let d=abs(a-b).
Thankyou for your replys, but this very last part i cannot actually figure it out how does it help?? do i need to show for example that abs(a-b) should be contained to this epsylon interval of a, and then conclude that this is impossible since the interval is of a distance of 2epsylon, while the distance abs(a-b) is of a distance of 3epsylon.
Can you please give me some more hints at this point??
Anyones hints would be really appreciated!
thnx
Do you think my hints wrong or something >.<? Or you just want to do an epsilon delta proof? Or Perhaps this is for a proof of my hint and hence circular to use it?
well actually i am looking for an epsylon delta proof. Using your hints, if i got it right, i could just take out the first term of the first sequence [tex]\ {(a_n)}[/tex]
, in other words ommit the [tex]\ {a_1}[/tex] term so now the two sequences would have equal terms and so their limits would be the same. Because the first part i proved, the part to show that the limits of these strictly increasing sequences exist, in both cases, when they are upper bounded and not. If this is what you meant Gib Z, thanks anyways, but i am looking for an epsylon delta proof, because it is more rigorous, this what u said(and what i had in mind) is more like an intuitive aproach.
But what I said in post 3 is a perfectly rigorous statement, a well known theorem. It can be proven.
ok then, does the rest of reasoning follow like i said in post #6??
And could you please post the whole theorem and the proof, this is the first time i hear it about sequences, i know that taking out or adding a finite number of terms to a series does not affect it, but as for sequences this is my first time i hear it, so i would really appreciate it Gib Z if you could post it, or just show me where i could find it.
thnx.
P.S. I really appreciate your help Gib Z, i really do and i am eager to see this kind of proof to my problem using your hints, but i also would like to know how to do it using delta epsylon.
so?
thnx
an outline of your prove.
d=abs(a-b) is a fixed real number depending on a and b
[tex]\lim_{n \rightarrow \infty} a_n = a \in \mathbf{R}[/tex] means that [tex]\forall \epsilon >0 \exists N(\epsilon)[/tex] such that if [tex]n > N(\epsilon) \Rightarrow abs(a- a_n )< \epsilon[/tex].
It must hold for all [tex]\epsilon > 0[/tex] ,so you are free to chose [tex]\epsilon= \frac{d}{3}[/tex].
let [tex]N_a=N(\epsilon)[/tex] for the series a_n and [tex]N_b=N(\epsilon)[/tex] for b_n.
let [tex]M=\max (N_a,N_b)+10[/tex]
look at [tex]a_M = b_{M-1}[/tex]. use the triangle inequality with a,b,a_M
