Cross section
by touqra
Tags: cross
touqra
touqra is offline
#1
Jan17-08, 05:32 PM
P: 284
What does it mean when they say s wave cross section, p wave cross section .. ?
Phys.Org News Partner Physics news on Phys.org
Better thermal-imaging lens from waste sulfur
Scientists observe quantum superconductor-metal transition and superconducting glass
New technique detects microscopic diabetes-related eye damage
malawi_glenn
malawi_glenn is offline
#2
Jan18-08, 01:47 AM
Sci Advisor
HW Helper
malawi_glenn's Avatar
P: 4,739
Quote Quote by touqra View Post
the [itex]l[/itex]-quantum number of the incoming wave. You often have a plane wave coming in to the target. The plane wave you write as a linear combination of spherical waves, and you call this "Partial Wave expansion".
http://farside.ph.utexas.edu/teachin...es/node70.html
The [itex]l[/itex] that you see in eq 957 is then the "[itex]l[/itex] - QM number".
And [itex]l[/itex] is denoted by, 0 = s, 1 = p, 2 = d, etc, same as in atomic physics notation.
Semiclassicaly, you can see the [itex]l[/itex] as the classical angular momenta of the incoming particle with respect to the centre of the scattering potential. And also the [itex]l[/itex] is quantisized, so only some values of [itex]l[/itex] are allowed.
Now since the sum goes to infinity in eq 957, we cut of where we expect no partial waves to contribute. And that is often assigned by [tex] l_{max} \approx R\cdot k [/tex]
Where R is the range of the potential and k is the momenta of the incoming particle (wave number).
Now the cross section is proportional to the scattering amplitude modulus square, i.e the modulus square of eq. 965 times a constant with alot of pi's hbar's etc.
So the s-cross section, you only have [itex]l[/itex] = 0 in you sum, and p-cross section only [itex]l[/itex] = 1. etc.
I hope you got the idea =)
Smoochie
Smoochie is offline
#3
Jan22-08, 01:40 PM
P: 3
Hello,
To munch the QM into an analogy:
Another way to look at is - how does one particle look to another. If you assume the target particle to be ball-like, then in its basic form (ground state), you'll get the classic 3D cross-section - this is how it will appear to the incoming particle and such it will be scattered from the target particle. But if the particle is excited to a higher state, then it will no longer appear as a ball but something else entirely. And vice versa.
Smoochie
Register to reply
Related Discussions
cross section High Energy, Nuclear, Particle Physics 5
Cross Section calculation Advanced Physics Homework 2
cross section weighting High Energy, Nuclear, Particle Physics 0
Cross section of a S wave Advanced Physics Homework 1
Absorption Cross Section Nuclear Engineering 1
