Change of variables for multiple integrals (2)
The discussion revolves around a problem involving multiple integrals and a change of variables in the context of a function defined over a specific region in R4. The original poster questions the validity of a step in a solution that appears to treat variables with explicit dependencies as interchangeable.
  • The original poster expresses confusion about the treatment of variables in the context of a change of variables theorem and the implications of dummy variables. Other participants provide insights on the nature of dummy variables and their interchangeability, while also questioning the explicit relationship between the variables involved.
Participants are exploring the nuances of variable substitution in integrals, particularly in relation to the dependencies between the variables. Some guidance has been offered regarding the concept of dummy variables, but the original poster still expresses discomfort with the treatment of the variables in the solution.
The original problem involves specific regions B and C in R4, and the discussion highlights the importance of understanding the implications of variable transformations in the context of integration. There is an ongoing examination of the assumptions underlying the change of variables and the definitions of the regions involved.
kingwinner
Q1: Suppose B=[0,1]x[0,2]x[0,3]x[0,4] in R4, and that C=[0,1]x[0,1]x[0,1]x[0,1]. Given that
∫ ∫ ∫ ∫f(x)=d4x=(2pi)4
B
What is the value of
∫ ∫ ∫ ∫ f(x1,2x2,3x3,4x4) d4x?
C[/color]
Solution:
Define x=G(u)=(u1,u2/2,u3/3,u4/4)
C
by change of variables theorem,
=(1/24) ∫ ∫ ∫ ∫ f(u1,u2,u3,u4) d4u
------B=G-1(C)
=(1/24)∫ ∫ ∫ ∫ f(u)d4u
---------B
=(2pi)4/24
I don't understand the last step...
We are only given that
B
NOT that
∫ ∫ ∫ ∫f(u)=d4u=(2pi)4
B
I will tell you what I am thinking about. Here, u=(u1,u2,u3,u4) and x=(x1,x2,x3,x4) CANNOT be treated as dummy variables since they have a relationship x=G(u) used to define the transformation G, but the last step of the solution seems to treat that x=u, which makes me feel very uncomfortable...
Can someone explain? I would really appreciate it!:smile:
Do you know what a "dummy variable" is?
[tex]\int_0^1 f(x) dx= \int_0^1 f(y)dy= \int_0^1 f(u)du[/tex]
In other words, it doesn't matter what the variable is called.
They have simply switched the first integral from "x" to "u" so as not to confuse it with the "x" in the second integral.
Dummy variable means we can replace by another letter not already in use while not changing the answer, right?
But x=G(u)=(u1,u2/2,u3/3,u4/4), there are explicit dependencies between u and x, does that matter?
What if, instead of x = G(u), you had used t = G(u)?
Well, I don't think this can happen at all...
The question is
"What is the value of
∫ ∫ ∫ ∫ f(x1,2x2,3x3,4x4) d4x?"
C
So we need a transformation that involves x, namely, x=G(u), right?
∫ ∫ ∫ ∫f(x)d4x=(2pi)4
B
B
NOT that
∫ ∫ ∫ ∫f(u)d4u=(2pi)4
B
There is no difference between the two. It doesn't matter that the variable you end up with is different than the variable you started with. You have an integral that is of the exact same form. Suppose it were originally given as this:
∫ ∫ ∫ ∫f(z)d4z=(2pi)4
B
Would that help you out?
B
Yes, this will sort of help.
The thing that really bothers me was that there is a relationship between x and u, so replacing x with u makes me feel uncomfortable...but I think I am OK now...
If you replace "x" by "t" (or any other symbol) and then make that replacement all the way through it should be obvious that it doesn't make any difference at all.
