Singularities and conservative vector fields
This discussion focuses on the properties of conservative vector fields and singularities in R². It establishes that a vector field with zero curl is conservative in open, simply connected subsets that do not include singularities, such as the origin. The participants confirm that the integral around closed curves enclosing a singularity can yield non-zero values, depending on the vector field. They conclude that if the curve integral around a singularity is a constant, such as 2π, this holds for all closed paths surrounding that singularity, provided the curl of the vector field remains zero along those paths.
  • Understanding of conservative vector fields
  • Knowledge of curl and its implications in vector calculus
  • Familiarity with path integrals in R²
  • Concept of singularities in mathematical analysis
  • Study the implications of Green's Theorem on line integrals and area integrals
  • Explore the relationship between curl and conservative fields in R³
  • Investigate the concept of homotopy and its effect on path integrals
  • Learn about potential functions and their role in determining conservative vector fields
Mathematicians, physics students, and anyone studying vector calculus, particularly those interested in the behavior of vector fields around singularities and the properties of conservative fields.
NewGuy
I have a question regarding conservative vectorfields and singularities.
Suppose we have a vectorfield who is defined everywhere in R^2 except at the origin where it has a singularity, and suppose it's curl is zero. We then have that it is conservative in every open, simply connected subset in R^2 not containing the origin.
Now if we have a closed curve around the origin we can't generally say that the curve integral is zero right? That depends on the given vectorfield? If we have calculated the curve integral around a circle with centre in the origin and shown that it is zero, can we then say that every closed curve around the origin has curve integral zero?
Suppose for example we have a square around the origin. Can we calculate the curveintegral for the whole square by adding the curveintegrals along the 4 sides?
Yes, if you have two distinct paths, both inclosing a singularity, then you can construct a line from one (call it Ca) to the other (CB) and just a slight distance away, a second line back to the first singularity Consider the integration from any point on CA, counterclockwise around CA to the first "cutoff", along it to CB, around CB, clockwise to the second "cutoff", along it back to CA, and finally around CA to the starting point. We know have integrals: IA' is almost IA,the integral around A- it does not include that small section of A between the two "cutoffs". I1 is the integral along the first "cutoff" from CA to CB. IB' is almost -IB, the negative of the integral around CB- it does not include the small section between the "cutoffs" (negative because we have to go clockwise around B). Finally, I2 is the integral along the second "cutoff" from CB back to CA. Because there in no singularity inside that path the integral is 0: IA'+ I1- IB'+ I2= 0.
Now, take the limit as we move the two "cutoffs" toward each other. Since, in the limit, they become the same path but integrated in opposite directions, in the limit, I1[/sub[+ I2= 0. Also, the left out sections between the two "cutoffs" disappear: in the limit IA'= IA, the integral all the way around A, and IB'= IB, the integral all the way around B. Since there is no singularity between the two cutoffs, the left side of the equation remains 0. In the limit, IA- IB= 0 so IA= IA.
As long as, moving one closed path to another, we do not cross any singularities, the integrals are the same.
The last part, "Suppose for example we have a square around the origin. Can we calculate the curveintegral for the whole square by adding the curveintegrals along the 4 sides?" is a completely different question but, of course, it is true. That's just saying that the sum of the two partial integrals is equal to the entire integral. I would think you did that back in basic calculus. Did you never do a path integral of a broken line?
This is a nice thing indeed! If we have that the curve integral around the singularity is 2 pi that is true for all closed paths around the singularity? I suspect that it is a requirement that curl(F) is zero everywhere along the path? Does the same thing apply to R^3?
Regarding the square: I meant a square around the singularity. I know that in a curve integral you can add the different paths together, I just didn't know if you could around a singularity.
So if we somehow can show that a vector field is the gradient of some function (by guessing at an appropriate function for example), it is true that the curve integral is zero for all closed paths, regardless if they surround the singularity?
  • · Replies 73 ·
9K
  • · Replies 26 ·
