| Thread Closed |
Electricity and Water Analogy |
Share Thread |
| Jan20-08, 02:19 PM | #1 |
Consider the following water circuit: water is continually pumped to high pressure by a pump, and then funnelled into a pipe that has lower pressure at its far end (else the water would not flow through the pipe) and back to the pump. Two such circuits are identical, except for one difference: the pipes in one circuit have a larger diameter than the pipes in the other circuit. Through which circuit is the flow of water greater?
Small pipe Large pipe If they didnt tell me about the velocity, how am i going to know about this?? |
| Jan20-08, 03:30 PM | #2 |
Mentor
I suppose this is homework? They do give you enough information to answer it. Hint: Velocity itself is not the critical issue.
| Thread Closed |
Similar discussions for: Electricity and Water Analogy
| with the water flow analogy | General Physics | 3 | ||
| Electricity and water analogy | Introductory Physics Homework | 5 | ||
| Electricity and impure water | Chemistry | 10 | ||
| Getting electricity from water tap | Electrical Engineering | 4 | ||
| Electricity from water | General Engineering | 6 | ||
