Approximation of the characteristic function of a compact set
The discussion focuses on approximating the characteristic function of a compact set through three specific mathematical problems. The first problem involves demonstrating that the function f(x) = e^{-1/x^{2}} for x > 0 is infinitely differentiable at x = 0. The second problem requires finding a function that transitions from 0 to 1 on the interval (0, ε). The third problem seeks a function that is 1 on a compact set K and transitions to 0 outside a closed set C containing K, utilizing the properties of e^{-1/x^2} for smooth transitions.
  • Understanding of real analysis concepts, particularly limits and continuity.
  • Familiarity with the properties of exponential functions and their derivatives.
  • Knowledge of compact and open sets in R^n.
  • Experience with constructing smooth functions and characteristic functions.
  • Study the properties of infinitely differentiable functions, particularly at boundary points.
  • Learn how to construct smooth transitions using bump functions in real analysis.
  • Explore the concept of compactness in topology and its implications for function approximation.
  • Investigate the use of closed balls in metric spaces for defining characteristic functions.
Mathematicians, students in real analysis, and anyone interested in the properties of functions related to compact sets and smooth transitions in mathematical analysis.
Mystic998
Okay, so this is a three-part question, and I need some help with it.
1. I need to show that the function [tex]f(x) = e^{-1/x^{2}}, x > 0[/tex] and 0 otherwise is infinitely differentiable at x = 0.
2. I need to find a function from R to [0,1] that's 0 for [itex]x \leq 0[/itex] and 1 for [itex]x \geq \epsilon[/itex].
3. For K compact, U open in [itex]R^n[/itex] and [itex]K \subset U[/itex], I need to find a function from U to [0,1] that's 1 on K and and 0 outside of some closed set C containing K and contained in U.
1. I can do the first part up to the second derivative pretty easily, I think. And I think that any derivative of [tex]e^{-1/x^2}[/tex] is going to be a polynomial times [tex]e^{-1/x^2}/x^n[/tex] for some n, so showing that the derivative of the function above is continuous at 0 just amounts to showing that [tex]\frac{e^{-1/x^2}}{x^n}[/tex] goes to 0 as x goes to 0. I just wanted to see if I have the right idea and if there might be an easier way.
2. For this one I think you just take [tex]f(x) = e^{-{(\frac{\epsilon - x}{x})}^{2}}[/tex] on the interval [itex](0,\epsilon)[/itex], then 0 and 1 where appropriate. Just checking to see if I'm way off or not here.
3. Now on this one I have very little idea what to do. I was thinking I could take 2 closed balls with [itex]K \subset C_{1} \subset C_{2} \subset U[/itex], then use [tex]e^{-1/x^2}[/tex] to define a function that's goes smoothly from 1 to 0 on [itex]C_{2} - C_{1}[/itex], but I'm not sure that's the best way to go about it.
Also, sorry for the TeX looking so nasty. The epsilons in the functions weren't very legible with the itex tag.
Just a quick bump before bed.
  • · Replies 18 ·
