Solve Lens Problem: Focal Length & Magnification
  • Thread starter Thread starter mustang
    Lens
The discussion focuses on solving lens problems involving focal length and magnification using a converging lens. For problem 24, with a focal length of 13.7 cm and a virtual image distance of -35.5 cm, the calculated magnification is approximately 4.02, indicating the virtual image is 4.02 times larger than the object. In problem 30, a magnifying glass with a focal length of 17.4 cm achieves a magnification of +2.06 when the object (nickel) is held at a distance of approximately 8.7 cm from the lens. Both calculations are confirmed as correct.
  • Understanding of lens formulas, specifically the lens maker's equation.
  • Knowledge of magnification calculations in optics.
  • Familiarity with converging lenses and their properties.
  • Basic algebra skills for solving equations.
  • Study the lens maker's equation for different types of lenses.
  • Learn about virtual and real images in optics.
  • Explore the effects of varying focal lengths on magnification.
  • Investigate practical applications of magnifying glasses in everyday scenarios.
Students studying optics, physics enthusiasts, and anyone interested in understanding the principles of lenses and magnification calculations.
mustang
Lens Problems
problem 24. A person looks at a gem using a concverging lense with a focal length of 13.7 cm. The lense forms a virtual image 35.5 cm from the lense.
a) Find the magnifaction.
This is what I have done so far:
f=13.7 , q= -35.5
1/p+1/q=1/f
1/f-1/q=1/p
1/13.7-(-1/35.5)=9.88516=p
M=-q/p
=--35.5/9.88516
= 4.02333
Is this right??
Problem 30. A magnifying glass has a converging lens of focal length 17.4 cm. At what distance from a nickel should you hold this lens to get an image with a magnificaiton of +2.06? Abswer in cm.
got p=8.7 and M=1.841932169 is this right?
You posted this same problem in College Help.
Yes, your calculations for both problems 24 and 30 are correct. For problem 24, the magnification is approximately 4.02, meaning the virtual image is 4.02 times larger than the object being viewed. For problem 30, the distance from the lens to the object (nickel) is approximately 8.7 cm. This means that the object should be held 8.7 cm away from the lens to achieve a magnification of +2.06. Great job!
