How Do You Construct a Stem-and-Leaf Display for Wood Specific Gravity Values?
  • Context: Undergrad
  • Thread starter Thread starter mr_coffee
    Stats Stem
This discussion focuses on constructing a stem-and-leaf display for specific gravity values of various wood types, as referenced in the article "Bolted Connection Design values based on European yield Model." The participant successfully categorized the values into stems and leaves, identifying stems as tenths and leaves as hundredths. The final display reveals two modes at 0.42 and 0.67, indicating typical soft and hard wood densities, respectively. The participant also notes the prevalence of low 40's values compared to high 70's values.
  • Understanding of stem-and-leaf displays
  • Familiarity with specific gravity concepts in materials science
  • Basic statistical analysis skills
  • Knowledge of data categorization techniques
  • Research how to identify modes in statistical data
  • Learn about outlier detection methods in datasets
  • Explore the application of stem-and-leaf displays in different fields
  • Study the properties of wood types and their specific gravities
Statisticians, materials scientists, students in statistics courses, and anyone interested in data visualization techniques.
mr_coffee
Hi everyone, I just started stats and had a question.
Question:
The accompanying specific gravity values for various wood types used in construction appeared in the article "Bolted Connection Design values based on Eurpoean yeidl Model"
.31 .35 .36 .36 .37 .38 .40 .40 .40
.41 .41 .42 .42 .42 .42 .42 .43 .44
.45 .46 .46 .47 .48 .48 .48 .51 .54
.55 .55 .58 .62 .66 .66 .67 .68 .75
Construct a stem-and-leaf display using repeated stems and comment on any interesting features of the display.An example of repeated stems are like:
For example, if evertyhing is in the 60's, 70's, 80's or 90's, we could use 6L for lower 60's. Like (leaves 0,1,2,3) and 6H for high 60's with leaves (5,6,7,8,9).
So for my problem above would it look somthing like this?
I have:
.30's, .40's, .50's, .60's, and a .75
So would I have for the .30 a High and a Low the low being (0, 1, 2, 3 , 4) and 3H (.30 HIGH) being (5,6,7,8,9).
so would it be something like this?
3L|1
3H|56678
4L|000112222234
4H|5667888
5L|144
5H|58
6L|2
6H|6678
7H|5
Then It wants me to label the Stem and Leaf.
For example if it was whole numbers like 60,70,80,88,etc
Stem would be the tens
Leaf would be the ones.
So because these are all like .30, .40,.50
Would the stem unit be tenths, and leaf: hundredths?
Also would the trend I'm seeing is that there a lot of low 40's but few high 70's?
Thanks!
I would label the stems as follows:
0.3L | 1
0.3H | 56678
0.4L | 000112222234
0.4H | 5667888
0.5L | 14
0.5H | 558
0.6L | 2
0.6H | 6678
0.7L |
0.7H | 5
And, yes, the stems are tenths and the leave are hundredths.
If we treat 0.55 and 0.75 as outliers, then two "modes" are apparent: 0.42 and 0.67.
Without looking at the original data, I might suspect that 0.42 was a typical soft wood and 0.67 was a typical hard wood.
  • · Replies 18 ·
16K
  • · Replies 58 ·
