Understanding Causes of Hall Light Blowing Fuse
  • Thread starter Thread starter Adz
    Fuse Light
The discussion revolves around the phenomenon of a hall light blowing a fuse in the distribution board when switched on. Participants explore potential causes for this occurrence, including the behavior of light bulb filaments and electrical circuit characteristics. The scope includes technical explanations and conceptual clarifications related to electrical systems.
  • One participant notes that a 5A fuse is small and questions whether it is at a distribution panel.
  • Another suggests that the light filament may have failed in a way that created a short circuit, potentially causing the fuse to blow.
  • It is mentioned that in the UK, a 5A fuse is standard for lighting circuits, with separate circuits for different floors.
  • Participants discuss the differences in circuit ratings between the UK and the US, with the US having higher amperage for residential circuits.
  • One participant describes how a broken filament can cause metal pieces to fly inside the bulb, possibly creating a brief short circuit that could lead to a current spike.
  • Another participant mentions that an arc can form through the argon in the bulb when the filament blows, which could lead to high current levels.
  • One participant measured the resistance of the blown bulb and found it to be an open circuit.
Participants express various hypotheses about the causes of the fuse blowing, but no consensus is reached regarding the exact mechanism. Multiple competing views remain on the nature of the failure and its implications.
Some participants reference specific electrical standards and practices in different countries, highlighting potential limitations in understanding due to regional differences in electrical systems.
Individuals interested in electrical engineering, home wiring, or troubleshooting electrical issues may find this discussion relevant.
Adz
Hi, can anyone explain this:
last night i switched on the hall light and the light blew. but it also blew the 5A fuse back at the dis board. My question is, why ?
Ive heard this happen before but when someone asked why, i couldn't explain it...
A 5A fuse is pretty small -- this is at a distribution panel?
My guess would be that the light filament failed in a way that mechanically left metal between the hot and neutral contacts for the bulb, in a way that survived long enough to pop the 5A fuse. Can you measure the resistance of the blown light bulb? Maybe the metal short is still there. Can you see in the bulb (is it clear?)?
Thats standard for a lighting circuit in the UK ( and presumably anywhere else with 240v)
you tend to have a separate circuit for each floor so there aren't that many lights on the one circuit and at 240V you have 1.2KW total.
Ah, thanks. I learn something new every darned day here on the PF!
Are receptacle circuits also 5A? In the US, standard residential circuits are 15A/120V= 1800w.
Thanks for the replies. Yes, Berkeman, the 5A is at the distribution board. I was thinking along the same lines as yourself, about the metal short just after the bulb blew However, with the bulb hanging down, any loose metal would have fallen onto just glass. I know this has happened to other people and when they ask me why, i can't answer! Out of curiosity i measured the resistance, but it is just 'open circuit'.
The filament is under tension. When the filament breaks, pieces of metal go flying about inside the bulb in a pretty violent fashion. It's possible some intermittent short existed for 100 milliseconds or so, producing a current spike large enough to push an already loaded fuse over the edge.
- Warren
They are 32A if you have a ring main or 16A for spur circuits. I have a very old house without ring mains and it's difficult to get electricians to understand this.
The maximum applicance fuse is 13A - so you can use a 3Kw kettle to make tea with properly boiling water!
As I understand it, when the filament blows, an arc forms through the argon in the bulb.
This can transfer down to the filament supports and can take up to 100A.
Many lightbulbs have an inbuilt fuse to prevent this taking out the fuse in the fusebox.
thanks! that sounds right to me!
15K
  • · Replies 24 ·
