| Thread Closed |
Expansion of a Gas into a Vacuum |
Share Thread | Thread Tools |
| Jan24-08, 02:48 AM | #1 |
A stop-cock which connects an evacuated flask with the atmosphere is opened and air at 1 atm and 17°C (290 K) enters. (a) What will be the temperature of the air in the flask before any heat has been transferred to the walls of the flask? Assume air to be a perfect gas and its molal heat capacity at constant pressure to be 7.00 calories per degree. Answer=132 °C (405 K) 2. The attempt at a solution I started working on this under the assumption that it was a throttling question with constant enthalpy: H2-H1=0 but I'm stuck at the point where you define enthalpy for each state. You can define the work done by the gas as: w=int(Cv dT,T,290,T2) where Cv=Cp-R (Cp=7 cal/K;Cv=5.013 cal/K) Any ideas on where to go? |
| Jan25-08, 09:04 PM | #2 |
Sounds like a free expansion of an ideal gas problem so the temperature change will be zero, i.e. the final temp is the same as the initial temp.
CS |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Expansion of a Gas into a Vacuum
| Accelerated Vacuum Space/ Universe Expansion | General Astronomy | 4 | ||
| Expansion of ideal gas into a vacuum | Introductory Physics Homework | 8 | ||
| Do vacuum fluctuations contribute to vacuum polarization | High Energy, Nuclear, Particle Physics | 2 | ||
| Does a Vacuum Cleaner work inside a Vacuum? | General Physics | 12 | ||
| Vacuum energy density and Hubble expansion | General Astronomy | 7 | ||
