Calculating Torque: A Gym Athlete's Challenge
  • Thread starter Thread starter leslie113
    Challenge Torque
The problem involves calculating the torque exerted by a steel ball and an athlete's arm while holding the arm straight out to the side. The subject area is physics, specifically focusing on torque and forces acting on a lever arm.
  • Exploratory, Assumption checking
  • The original poster attempts to calculate torque using a formula but expresses confusion about the role of the arm's weight in the calculation. Participants question where the weight of the arm acts and discuss the implications of its center of mass on the torque calculation.
Participants are actively engaging with the problem, exploring the importance of considering the arm's weight and its center of mass. Some guidance has been provided regarding how to approach the calculation of total torque by considering both the ball and the arm.
There is a lack of information regarding the exact location of the center of mass of the arm, which is noted as a potential complication in the calculations.
leslie113
Simple Torque Q :)
1. Homework Statement [/b]
An athlete at the gym holds a 3.64 kg steel ball in his hand. His arm is 65.0 cm long and has a mass of 5.59 kg. What is the magnitude of the torque about his shoulder if he holds his arm straight out to his side, parallel to the floor?
2. Homework Equations [/b]
t= rfsin theta
3. The Attempt at a Solution [/b]
t= (0.65)[9.81 (3.64+5.59)] sin 90
= 58.8N*m
WHAT AM I DOING WRONG? i don't get it :*(
Where does the weight of his arm act?
This is where i think the problem is too. I don't know how to account for the weight of the arm in the solution. But i know we have to, since if i just do without, the answer is wrong as well.
But doesn't the weight like the ball just acts to pull the torque downwards towards the pull of gravity? so i can clump it together with the weight of the ball?
Absolutely not! In calculating the torque due to any force, the distance from the axis is critical. The weight of anybody acts at the body's center of mass. If you aren't given any details about where the center of mass of the arm is, just assume it's at the center of the arm.
The total torque will be the sum of the torque due to the weight of the ball (which acts at the end of the arm, since it's in the hand) and the torque due to the weight of the arm.
WOW! you are amazing. i totally get what I'm doing wrong now. thanks for the ultra fast replies and being so clear and concise with your hints! :)
I realllly appreciate your help!
16K
11K
13K
