Sound Wave quesions (Grade 11 Physics)
The discussion focuses on two key physics concepts related to sound waves and tuning instruments. The rising pitch noise when filling a gasoline tank is attributed to the formation and collapse of standing waves in the air column, which increases frequency as the tank fills. Additionally, Liona Boyd's tuning process reveals that the possible frequencies of her guitar string are 440 Hz, 445 Hz, and 450 Hz, with the need for further adjustments using the tuning fork to achieve a precise frequency match.
  • Understanding of standing waves in air columns
  • Knowledge of beat frequency concepts
  • Familiarity with tuning forks and their application in musical tuning
  • Basic principles of frequency and pitch in sound waves
  • Research the principles of standing waves in different mediums
  • Explore the concept of beat frequencies in sound waves
  • Learn about the physics of tuning instruments, specifically guitar strings
  • Investigate the relationship between frequency, tension, and pitch in stringed instruments
Students studying Grade 11 Physics, music educators, and anyone interested in the physics of sound and musical tuning techniques.
pkevin91
1. "When filling your car with gasoline, in the last few seconds before filling the tank, a noise with a rising pitch comes from the tank. Explain"
2. "Liona Boyd, a famous Canadian guitarist, tunes her guitar's A string with a 440 Hz tuning fork. Beats are heard at a frequency of 4 Hz. To give herself more information, Mrs. Boyd wraps a piece of masking tape around one of the tuning fork tines and continues tuning. This time, a beat frequency of 5 Hz is heard. Is more information required to find the specific frequency of the string? What are the possible frequencies of the string? In each case, what should Ms. Boyd do to tune the string?"
1. The teacher told me to think about the standing waves in air columns.
2. No idea :P...
1. The noise with a rising pitch is likely caused by the growth and subsequent collapse of standing waves in the air column inside the tank. As the tank is filled, the pressure of gas increases, leading to an increase in frequency of the standing waves. This results in the noise becoming higher pitched as the tank is filled. 2. More information is required to find the specific frequency of the string. Possible frequencies of the string are 440 Hz, 445 Hz, and 450 Hz. For each case, Ms. Boyd should use the tuning fork to compare the frequency of the string to the frequency of the tuning fork. She should then adjust the tension on the string and repeat the process until she achieves a frequency match.
  • · Replies 43 ·
10K
