Is it not possible to travel in light speed?
The discussion revolves around the possibility of traveling at light speed, exploring the implications of Einstein's equation E=mc^2 and its relationship to kinetic energy and relativistic physics. Participants examine the conditions under which objects can approach light speed and the mathematical formulations that describe these scenarios.
  • One participant suggests that if E=mc^2, then 1/2mv^2=mc^2 could imply that to travel near light speed, an object must reach twice the speed of light, raising questions about the validity of this reasoning.
  • Another participant clarifies that E=mc^2 applies to an object at rest and introduces the correct relativistic energy equation E^2 = m^2 c^4 + p^2 c^2, emphasizing the role of momentum in relativity.
  • A later reply discusses the confusion surrounding the application of kinetic energy formulas in textbooks, questioning whether it is conceptually incorrect to link rest energy with non-relativistic motion equations.
  • One participant explains that as an object's speed approaches the speed of light, the relativistic factor gamma approaches infinity, indicating that infinite energy would be required to reach light speed.
  • Another participant expresses confusion about the integration of Newtonian equations with quantum phenomena, particularly regarding the conservation of momentum and the behavior of photons, suggesting a lack of clarity in distinguishing between quantum principles and Newtonian mechanics.
  • Concerns are raised about textbooks not incorporating the full relativistic equations, leading to misconceptions about the relationship between kinetic energy and mass at high speeds.
Participants express differing views on the application of kinetic energy equations and the implications of relativistic physics. There is no consensus on the correctness of the interpretations of E=mc^2 in relation to kinetic energy or the integration of Newtonian and quantum mechanics.
Some participants note limitations in textbooks that fail to incorporate the full relativistic equations, which may lead to misunderstandings about energy and mass at high speeds. The discussion highlights the complexity of linking classical and modern physics concepts without clear distinctions.
Seek45
Hi
I am just wondering if E = mc^2 then wouldn't it also be correct to say 1/2mv^2=mc^2 since E is kinetic energy. So in order for an object to travel near light speed, it has travel twice (1/2v^2=c^2) the speed of light according to the above formulae. But according E=mc^2 light speed is the limit as energy turns into mass. This lead to the idea that no matter how advanced things are, unless preventing energy turning to mass, it's not possible to travel close to speed of light. Or is the entire derived above formulae incorrect?
If it incorrect but is it really possible to travel close to light speed as a concept?
Seek45 said:
Hi
If m is the object's rest mass, the equation E=mc^2 only applies to an object at rest, for an object in motion with nonzero momentum p, the correct equation is [tex]E^2 = m^2 c^4 + p^2 c^2[/tex], and in relativity momentum is not mv but rather [tex]\gamma mv[/tex], where [tex]\gamma = \frac{1}{\sqrt{1 - v^2/c^2}}[/tex]. With a little algebra, the above formula can be rearranged as [tex]E = \gamma mc^2[/tex]. Since the "rest energy" is just [tex]mc^2[/tex], the kinetic energy in relativity is not (1/2)mv^2 but rather [tex](\gamma - 1)mc^2[/tex], so that when you add the kinetic energy and the rest energy you get back the total energy [tex]\gamma mc^2[/tex]. It's possible to show that in the limit as v gets very small relative to c, the relativistic kinetic energy [tex](\gamma - 1)mc^2[/tex] approaches the Newtonian kinetic energy (1/2)mv^2.
Ah alright thanks, I had no idea that relativity equation also applies to E=mc^2. Just to digress a bit, I found textbooks explaining the equation in kinetic motion - such as turning energy into mass - without the relativistic equation. Wouldn't be conceptually incorrect for them to use the rest energy arrangement as it links special relativisty's concept of motion with non-special relativity of motion equation? I am not sure if I laid out my ideas correctly but I hope you can understand it.
What did they say, exactly? Do you mean that they were using E=mc^2 rather than E^2 = m^2c^4 + p^2c^2, or do you mean that they were using K.E. = (1/2)mv^2 rather than K.E. = (gamma - 1)mc^2? And what example of "turning energy into mass" were they using? It might help if you just quoted a paragraph or two from whatever section is confusing you...
seek, to answer the original question about traveling at light speed, if you look at the equation
by studying the definition
[tex]\gamma = 1/\sqrt{1-v^2/c^2}[/tex]
you can see that as v approaches c, [tex]\gamma[/tex] approaches infinity, so the energy approaches infinity. It takes infinite energy for a particle to travel at c. That is, as you can also see from the equation, unless the mass is zero.
I believed I was confused when they linked Newtonian equation into quantum phenomena. Such as linking P = h/lamba with Newtonian momentum to show the Law of Conservation of Momentum with photon applying to subatomic particles. Since it was photons I presumed they were talking about the speed of 3 x 10^8 m/s and with their De Broglie explanation they stated that lamba = h/mv. They tried to show the relationship between Newtonian equations with Quantum world as like the one shown above. They didn't really draw a clear line between Quantum principles with Newtonian's. As you have stated above that gamma must be incorporated in these equations such as special relativity's momentum, they (Quantum principles and Newtonian's) seemed more distincted from one another.
With E=mc^2 issue, yes, they didn't incorporate full equation and expected using E = mc^2 to give the full understanding of kinetic energy and mass being proportional when close light speed. As they explained also that mass energy changing to mass such as protons getting heavier when close to light speed according to them; they didn't use E =(gamma)mc^2 so bringing to the misconception of 1/2mv^2 = mc^2.
  • · Replies 26 ·
  • · Replies 16 ·
  • · Replies 51 ·
  • · Replies 53 ·
  • · Replies 22 ·
  • · Replies 25 ·
  • · Replies 38 ·
  • · Replies 26 ·
