| Thread Closed |
Curvilinear Motion |
Share Thread | Thread Tools |
| Jan26-08, 05:15 PM | #1 |
Curvilinear Motion
A particle moves along the curve [itex]y(x)=x^2-4[/itex] with constant speed of 5 m/s. Determine the point on the curve where the max magnitude of acceleration occurs and compute its value. 2. Relevant equations radius of curvature [tex]|a|=\sqrt{a_n^2+a_t^2}[/tex] 3. The attempt at a solution I have assumed that 'constant speed' means [tex]v_t=5 \Rightarrow a_t=0[/tex] So now I have to find where a_n is maximum. Any hints to get me going here? Thanks, Casey |
| Jan26-08, 05:26 PM | #2 |
So I got the right answer. But I don't know how to spell out a proper procedure for future problems.
I found y'(x)=0; at x=0. So x=0 is a critical point. Then I just plugged that into [tex]a_n=\frac{[1+\frac{dy}{dx}^2]^{3/2}}{\frac{d^2y}{dx^2}}[/tex] and that worked. But do I know that x=0 is a MAXIMUM, if I do the second derivative test, I get positive 2, so I would have thought it was a minimum. |
| Jan26-08, 05:44 PM | #3 |
Can anyone point out how I would know it was a maximum? Shouldn't the 2nd derivative test work here?
| Jan26-08, 05:58 PM | #4 |
| Jan26-08, 06:06 PM | #5 |
You should note here that x = x(t), that is, position is a function of time. And that the maximum acceleration would occur when x'''(t)=0 and not when y''(x)=0.
| Jan26-08, 07:46 PM | #6 |
| Jan26-08, 08:49 PM | #7 |
| Jan26-08, 08:55 PM | #8 |
Have you studied parametric equations? I'm guessing that's exactly what you're doing right now, from the looks of this problem.
If you can restate the problem by writing independent eqations for y(t) and x(t) (i.e. parametrically), then you'll be set. The key is that you know how x and y are related, and you know that the magnitude of the velocity (i.e. the speed) is constant. Do you know how to express the velocity vector for parametric equations? |
| Jan26-08, 08:58 PM | #9 |
I have actually never studied them. This is for a dynamics course. I have probably studied them, but never heard them worded as "parametric". Give me an example, if you would.
| Jan26-08, 09:07 PM | #10 |
Oh, then maybe that's not the way to go. It's where you have separate equations for x(t) and y(t) and then you use the chain rule a lot to express dy/dx in terms of dx/dt and dy/dt.
If you haven't seen it, then you probably have to stick with expressing the normal acceleration as a function of the curvature. Do you know how to do that? I'm not sure I remember, myself ...
| Jan26-08, 09:13 PM | #11 |
No...you're right, it does have to do with the chain rule. I am just confused by it....that, is I do not have a nice procedure as to where to start or how to set it up.
I have y as a function of x. Now what? |
| Jan26-08, 09:25 PM | #12 |
Can I jump in?
![]() First of all constant velocity means [itex]u^2=u_x^2+u_y^2=C[/itex]. Thus first take the derivative of [itex]y(t)=x(t)^2-4[/itex] to find the relation bewteen [itex]u_x,\,u_y[/itex] and plug it in [itex]u^2[/itex] |
| Jan26-08, 09:47 PM | #13 |
| Jan26-08, 09:53 PM | #14 |
The [itex]y,\,x[/itex] are actually [tex]y(t),\,x(t)[/itex]. Can you take the derivative of [itex]y(t)=x(t)^2-4[/itex] with respect to [itex]t[/itex]?
Hint. [itex]u_x=\dot{x}(t),u_y=\dot{y}(t)[/itex] |
| Jan26-08, 10:02 PM | #15 |
I am sorry, I cannot follow any of your notations. I have y(x) not y(t). . . where are you getting t? What is u? Where am I?
| Jan26-08, 10:08 PM | #16 |
Ok!
![]() The partile is moving in the plane x-y. Thus x,y varies with time, i.e. [itex]x(t),y(t)[/itex] and the velocity [itex]\vec{u}[/itex] has two compontents, i.e. [itex]u_x=\frac{d\,x(t)}{d\,t},\,u_y=\frac{d\,y(t)}{d\,t}[/itex] and the magnitude of the velocity is [tex]u^2=u_x^2+u_y^2[/tex] Do you follow up to now? |
| Jan26-08, 10:14 PM | #17 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Curvilinear Motion
| simple curvilinear motion problem | Advanced Physics Homework | 1 | ||
| Dynamics: Curvilinear motion | Advanced Physics Homework | 9 | ||
| FDM on curvilinear coordinates | Differential Equations | 0 | ||
| Curvilinear Unit Vectors | Differential Geometry | 9 | ||
| Curvilinear Motion | Introductory Physics Homework | 1 | ||
