Where is the Electric Field Zero Between Two Point Charges?
The problem involves determining the location along the x-axis where the electric field is zero due to two point charges: a positive charge at the origin and a negative charge at x = +2.0 m. Participants are exploring the implications of charge interactions and the conditions under which the electric field can be zero.
  • Participants discuss the setup of the electric field equations based on Coulomb's law and the distances from the charges. Some express confusion about the quadratic formula and the presence of imaginary numbers in their calculations. Others suggest considering the regions along the x-axis to determine where the electric field could potentially be zero.
There is ongoing exploration of the problem, with participants questioning the validity of their approaches and the assumptions about the regions where the electric field might be zero. Hints have been provided to guide the reasoning about the direction of the electric fields from each charge.
Participants are considering the implications of having opposite charges and the behavior of electric fields in different regions along the x-axis. There is a noted frustration with the complexity of the problem and the lack of clarity on the next steps to take.
marissag
A positive point charge Q1 = 1.9 x 10^-5C is fixed at the origin of coordinates, and aa negative charge Q2 = -6.5 x 10^-6C is fixed to the axis at x = +2.0m. Find the location of the place(s) along the x-axis where the electric field due to these two charges is zero. IF there is only one location then enter zero for the second location.
x = ______m
x = ______m
for the distance I used Q1 = x and Q2 = abs val of 2-x and then used the equation of Q1/r1^2 = Q2/r2^2
so I started out with ::::
first (1.9 x 10^-5C)/x^2 = (-6.5 x 10^-6C)/((2-x)^2)
then (1.9 x 10^-5C)/x^2 = (-6.5 x 10^-6C)/(x^2-4x+4)
then multiplied both denominators to get rid of them and got:::
(1.9 x 10^-5C)(x^2-4x+4) = (-6.5 x 10^-6C)(x^2)
then multiplied them all out and got:::
(2.55 x 10^-5C)(x2) - (7.6 x 10^-5)(x) + ((7.6 x 10^-5) = 0
at this point I used the quadratic formula and used:::
a = 2.55 x 10^-5
b = 7.5 x 10^-5
c = 7.5 x 10^-5
Now...here is the problem. When I plug these all into the quadratic formula I end up with a negative number in the square root which you can't take the square root of...
any help is appreciated...anybody to show me where I went wrong is appreciated as well!
First let's look at Coulomb's law, just because LaTeX is pretty if nothing else:
[tex]\vec{E}=\frac{1}{4\pi\epsilon_0}\sum{\frac{q_i}{r'_i^2}\hat{r}}[/tex]
Now, I would like to point out that r' here is the separation between the point in space we are looking at and the charged particle.
Okay, right away because everything is on the x-axis we can ignore the vector aspects of this and let's get rid of the summation and look at it that way:
[tex]E_x=\frac{1}{4\pi\epsilon_0}\left( \frac{q_1}{x_1^2}+\frac{q_2}{x_2^2}}\right)[/tex]
Where [tex]x_1[/tex] is the distance between some point and the first charge, and [tex]x_2[/tex] is the distance between the point and the second charge. Since that's two variables dependent on the point in space (let's call it [tex]x_0[/tex] since E is zero there), let's substitute the point in:
[tex]E_x=\frac{1}{4\pi\epsilon_0}\left( \frac{q_1}{x_0^2}+\frac{q_2}{(x_0-2)^2}\right)[/tex]
Now set that equal to zero, and solve for [tex]x_0[/tex].
Comes out as:
[tex]x=\frac{2\sqrt{q_1}*(\sqrt{q_1}\pm\sqrt{-q_2})}{q_1+q_2}[/tex]
Which does not have any imaginary numbers.
Comes out as:
Okay...so I set it up as this says...
(2sqrt 1.9x10^-5)(sqrt 1.9 x 10^-5 * sqrt -(-6.5 x 10^-6)
answer I received is 6.02 x 10^-5 however the answer is showing incorrect in my homework program. I am just totally confused on this one. I guess the way I was doing it at first was completely incorrect...
am I still missing something?
Well, if that one doesn't work, what does the other possibility say? (remember that's a plus or minus sign in there).
okay...totally forgot about the plus and minus signs.
So now I have a for the first equation (plus) 6.02 x 10^-5
and for the second equation (minus) 1.58 x 10^-5
The distance given for Q2 is on the x-axis at 2m. So I am needing to find where the electrc field due to the charges is zero.
Hint: First figure out which region the answer must be in. (x < 0, 0 < x < 2, x > 2) Then set up the expression for total field.
The hint is kinda sort of helping a little...
considering the charges I am thinking that the point is going to have to be 0 < x < 2
as far as the equation I am not really sure what equation I should be using to find the point on this problem once having both charges...
If as you stated the charges are of opposite sign (one negative and one positive) the potential may be zero at a point between them, but not the electric field. Remember what the direction of the electric field originating from the charges, one is going radial outward and one is radial inward (in 2D).
Look at this thread:
https://www.physicsforums.com/showthread.php?t=153273
That post was full of drama is really all that i noticed...as far as this problem I will just go to the physics help lab tomorrow...I don't understand it and at this point all I am doing is getting more and more frustrated. I don't know the next step...I have beeen working on this for two days and finally posted to ask for help last night...I don't know what else to do.
The way to see that this could not be the correct region is to figure out which way the field from each charge points. Q1, a positive charge, creates a field pointing outwards--thus for x > 0 it points to the right. Q2, a negative charge, creates a field pointing inwards--thus for x < 2 it also points to the right. So there's no way that the two fields can cancel in the region 0 < x < 2.
So it's got to be in one of the other two regions. You can try to reason it out--by considering the relative size of the charges. Or you can just set up the field equation for each region (one at a time, of course) and see if you get a sensible answer.
The field from each charge has a magnitude of kq/r^2, where q is the magnitude of the charge and r is the distance from the charge. You will assign the direction depending on the region you are examining. For example, for x > 0, the field from Q1 is positive (since it points to the right); but for x < 0, the field from Q1 is negative.
  • · Replies 17 ·
  • · Replies 19 ·
