How Fast Does a Penguin Slide on Ice After 8.75 Seconds?
The problem involves a penguin sliding on frictionless ice, initially moving at a speed of 0.75 m/s along the x-axis and being pushed by a wind force. The task is to calculate the penguin's speed after 8.75 seconds and determine the direction of its velocity with respect to the x-axis.
  • Mixed
  • Participants discuss the calculation of the penguin's speed and the angle of its velocity vector. There are attempts to clarify the setup of the problem and the correct use of trigonometric functions to find the angle.
Some participants have provided guidance on the correct approach to finding the angle of the resultant velocity vector, while others have questioned the initial setup and assumptions made in the calculations. There is acknowledgment of a mistake in the problem statement by the original poster.
There is a mention of confusion regarding the problem statement, with the original poster indicating that they copied the wrong problem initially. The discussion reflects on the need for clarity in the problem setup and the definitions used.
anastasiaw
A car that weighs 12000.0 N is initially moving at a speed of 30.0 km/hr when the brakes are applied and the car is brought to a stop in 4.1 s. Find the magnitude of the force that stops the car, assuming it is constant.
This is the wrong problem ^^^
A 6.70 kg penguin runs onto a huge horizontal sheet of frictionless ice. The sheet lies on the xy-plane. At t = 0 s it is at x = 0 m and y = 0 m with an initial speed of 0.75 m/s along the positive x-axis. It slides while being pushed by the wind with a force of 0.37 N directed along the positive y-axis. Calculate the penguin's speed at t = 8.75 s.
F=ma => 0.37=6.7a => a=0.6 m/s^2
vy(t )= vy0 + at = 0 + .06(8.75) = 0.483 m/s
v(t)^2 = vx(t)^2 + vy(t)^2 = 0.75^2 + 0.483^2 = 0.796
v(t) = 0.892 m/s
This part is CORRECT.
Calculate the direction of his velocity at that time. Give the angle with respect to the x-axis.
Set the vectors up as a right triangle, find the angle between the resultant vector and the x-vector.
x-vector: 0.75 m/s
y-vector: 0.483 m/s
angle should be: sin^-1(y/x) = sin^-1(.483/.75) = 40.1 deg
This part is INCORRECT.
What did I do wrong?
I don't see why you're setting up right angles. The problem appears one dimensional to me. Are you leaving something out? Did you mean acceleration instead of velocity?
"Draw the components of the resultant velocity and extract the answer from the right triangle you obtain. The angle must be between 0 and 2 pi radians."
That's what it told me when I entered the incorrect answer. I'm taking the x-component of the velocity and the y-component and setting them up tip-to-tail. The resultant vector should be the magnitude and direction of the velocity I was looking for in the first part (and I got the magnitude part right).Edit: I'm sorry -- I wrote the first part of the problem wrong. Actually I copied the wrong problem. I'll fix that.
Figured it out: for some reason I was thinking "soa" instead of "toa" -- tan of an angle = opposite/adjacent
So I should have done arctan (y/x) which yields 32.8 deg; this is the correct answer.
Ah yes, I suspected something off. Glad you got it worked out on your own.
  • · Replies 24 ·
11K
