Finding Distance Up (Max Height) trouble
  • Thread starter Thread starter Mirth
    Height Max height
The discussion revolves around a physics problem involving projectile motion, specifically calculating the maximum height reached by a projectile launched at an angle of 30 degrees with an initial velocity of 10 m/s. Participants are attempting to derive the "Distance Up" using various equations related to motion.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the initial and final velocities, questioning how to apply the equations of motion correctly. There is confusion regarding the use of time and the correct initial velocity component for the vertical motion.
Some participants have provided guidance on identifying the correct initial velocity and time to use in the calculations. There is ongoing exploration of the effects of gravity on the equations, with no clear consensus reached yet.
Participants note that they have not yet covered vector equations in class, which may be contributing to the confusion. There is also mention of discrepancies in the values used for initial velocity and time, leading to incorrect calculations.
Mirth
Hey guys, I just started a physics class in college and I'm having a hard time understanding most of it, but I'm trying...
Anyways, I'm trying to find "Distance Up" for the problem below, and I just can't understand how the professor got 1.28m for his answer.
A projectile launched at an angle of 30 degrees, and a velocity of 10 m/s.
Find:
Horiz. Vel. (I got 8.66 m/s)
Vert. Vel. (I got 5 m/s)
Time Up (He gave us this, .51 sec)
Total Time (I got 1.02 sec)
Distance Up (Can't figure this out...)
Distance (I got 8.84 m)
Distance Up = (Final Vel^2 - Initial Vel^2) / 2 * Acceleration
or = Initial Vel * Time + 1/2 * Acceleration * Time^2
Well, I'm having a hard time figuring out how to get Final Velocity with this type of problem...
I mean, the initial velocity should 0, so when I plug that into the 2nd formula I get:
(0 * 1.02) + (1/2) * 9.8 * 1.02^2 = 5.09796
But the correct answer should be 1.28 m...
Hi Mirth. Welcome to PF!
No, it is not. It is given in the problem that the velocity of the projectile at launch is 100m/s. (This is the initial velocity.)
As for the final velocity, it's the same as the velocity of a ball (that you throw straight up) when it reaches the maximum height. (The ball you throw up is also an example of a projectile, but it doesn't travel horizontally like the object in the problem.)
Oh, I see I see.
I also messed up in my original post putting 100m/s for velocity, when it's supposed to be 10 m/s. I'll edit that now.
But anyways, so if the initial velocity is 10 m/s, then in the second formula, it should be:
10 * 1.02 + (1/2) * 9.8 * 1.02^2
And I get 15.29796 for an answer, so I'm not sure what I'm putting in wrong. :(
I made a slight but significant error in my earlier post, so please forgive me. :) :redface:
The initial velocity in this case is the vertical component of the velocity with which it was thrown.
And for the time, you shouldn't be using 1.02s. Can you see why?
Hehe, it's no problem.
So you're saying Initial Velocity is the Vertical Velocity that I found, which is 5 m/s.
As for the time part... I guess I should be using the "Time Up" I got before (.51 sec) because the point of the highest distance is at the time it took to get up to that point, which is the halfway point...
If that is so though, then the formula would be: 5 * .51 + (1/2) * 9.8 * .51^2, which I get 3.82449, which is still wrong.
I'm really terrible at the thinking part of this. :(
Yes.
Correct again.
What you have there is really a vector equation. (Have you studies those yet?) It takes into account the directions of certain quantities as well. As per convention, in an x-y coordinate system, the +y axis points "upwards." The initial velocity points up and is therefore positive, but what about gravity?
We haven't really learned anything about this chapter yet in class, so I'm just trying to use my book as a source (it feels horribly unorganized...), so I guess we haven't studied vector equations yet.
As for your question, I guess gravity would be negative because it's is pulling the object down...
And how would that affect the equation
Distance = Initial Vel * Time + 1/2 * Acceleration * Time^2
It'd be a negative number; -9.8
neutrino said:
That's the formula he gave us to find Distance for this problem. Even if I use the -9.8, I get a really odd number.
I think I'm just going to skip this problem.
It's the same formula, except that I inserted -9.8, instead of +9.8.
  • · Replies 30 ·
