| Thread Closed |
Why should a series motor always start with a load? |
Share Thread | Thread Tools |
| Jan30-08, 10:22 AM | #1 |
Why should a shunt motor always start without a load? |
| Jan30-08, 11:05 AM | #2 |
I'm pretty sure this is a homework question, so what do you think? By the way, there must be more to this question since it is not correct as written.
| Feb9-08, 09:19 AM | #3 |
In any DC motor the speed depends inversely on the flux. Consider when starting a series motor the current flowing will be high, but the flux that the motor produces will be moderate since the series winding has less number of turns. If u start the motor without load the speed will increase. as speed increases the back emf increases. this decreases the current through the series winding and hence flux decreases and the speed further increases. Theorerically speaking the speed becomes infinite. But practically the motor will accelerate to very high speed , which will damage the motor. But if you start the motor with the load, you are actually reducing the starting speed hence the motor runs safely. Since series motors has this property it is used in trains to pull high load.
| Feb9-08, 09:49 AM | #4 |
It is correct to say that a dc series motor can start at quite (even startlingly) high speeds, but don't you use any control? Are there no power electronics people on your railroad?
BTW, the OP was about series motors not specifically dc series. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Why should a series motor always start with a load?
| The recoil of a dc motor at start-up | General Physics | 15 | ||
| How do I find Capacitor rating to start / run Single phase motor | Electrical Engineering | 5 | ||
| DC Series Motor Drum Controller | Electrical Engineering | 3 | ||
| Capacitive Start Motor | Electrical Engineering | 2 | ||
| Get a load of this BS. | General Discussion | 13 | ||
