Beam-break sensors for ignition delay measurement
The discussion revolves around the design and implementation of a beam-break sensor system for measuring the ignition delay of fuel droplets. Participants explore various sensor types, circuit designs, and operational challenges related to high temperatures and pressures in the context of mechanical engineering applications.
  • One participant describes a project involving the use of optical beam-break sensors to measure ignition delay, seeking advice on circuit design and sensor selection.
  • Another participant suggests that standard photointerrupter components may not withstand high temperatures, recommending the construction of a custom sensor using an LED and a PIN photodiode.
  • A different approach is proposed involving a laser and a photo detector, with recommendations for data acquisition systems like GageScope or LabView for measuring ignition onset and droplet durations.
  • Participants discuss the importance of fast response circuits, with one emphasizing the use of photodiodes in reverse bias for effective measurement.
Participants present multiple competing views on the best sensor and circuit design for the application. There is no consensus on a single approach, as different methods are suggested based on varying operational requirements and preferences.
Participants express uncertainty regarding the suitability of commercial photointerrupters for high-temperature environments and the need for custom solutions. There are also unresolved considerations about the specific circuit configurations and components that would be optimal for the proposed measurements.
saguntripathi
Hi all..
I have been working on a project which involves the measurement of ignition delay of fuel droplets using optical sensors of the beam-break type. What my project supervisor has asked me to do is to fabricate an apparatus in which such measurements could be made. The basic principle would be to trigger a stop watch as soon as the beam of the sensor is intercepted by a fuel droplet and stop the timer as soon as ignition takes place.
Being a student of mechanical engineering I do not have much knowledge of sensors and other electronic circuit components. I have been browsing the internet for a while now looking for sensors and the suitable circuit that would be required in this case. During my search I also found out that photodiodes in reverse bias have very high resistance and their resistance decreases when light falls upon them. I was wondering how could this change in resistance be utilized for triggering a stop-watch.
Can anyone suggest a possible circuit design for measuring the ignition delay?
The operating temperatures and pressures would be quite high and so the sensor should be able to work in those conditions as well.
It would be nice if anyone could help. Thanks
Wecome to PF.
I hate to see you sitting here all by yourself, but I can't help. There are, however, people here who can. I'm sure that one of them will be along shortly.
Here is a selection of Photointerrupter circuits from Digikey. Select some simplifying terms in the menus, and click on "Apply Filters":
http://www.digikey.com/scripts/dksearch/dksus.dll
But, your temperature requirements are going to likely be too high for simple production photointerrupter components, so you will likely need to make your own from LED and a PIN Photodiode, both somehow housed outside of the fuel droplet path (both to isolate them from the high temperatures, and to make sure that they don't interfere with the combustion process (standard photointerrupters are not intrinsically safe devices).
This wikipedia.org article will start to give you some background on the operation of a photodiode:
http://en.wikipedia.org/wiki/Photodiode
You will likely want to have a fast responding circuit, so that means using a photodiode (not a phototransistor or other photosensor), in reverse bias in a fast current-to-voltage circuit, like figure 13 here:
http://en.wikipedia.org/wiki/Current-to-voltage_converter
best way is to use a laser can be cheap (HeNe) and have a photo detector on the other side. Then you put the input of that detector into a fast data acquisition system (GageScope is great) LabView is also good. You can also use a stand alone digital oscilloscope although they are a little less user friendly and sometimes a little more expensive. Anyway, this is the way we measure spray and droplet durations in shock-tubes, also, onset of ignition can easily be measured using a photo detector (PMT) in combination with the right filter (OH* at 310 nm and CH* at 430 nm). Please let me know if you have any specific questions because I am pretty familiar with these kind of setup.
  • · Replies 21 ·
