Calculate Heat of Melting Ice at 10 atm - Derive Equations & Assumptions
  • Thread starter Thread starter glenL
    Thermodynamics
The heat of melting ice at 1 atm and 0 degrees Celsius is +5.9176 kJ/mol, with ice density at 0.917 g/cm³ and water density at 0.9998 g/cm³. To calculate the melting point at 10 atm, the discussion emphasizes deriving equations and making necessary assumptions. The formula dp/dt=(s2-s1)/(v2-v1) is proposed for application, though its correctness is questioned. The relationship between entropy (s), enthalpy (h), and melting temperature (Tm) is also explored for expressing Δs in terms of Δh.
  • Understanding of thermodynamic principles, specifically phase changes.
  • Familiarity with the concepts of enthalpy (ΔH) and entropy (ΔS).
  • Knowledge of the Clausius-Clapeyron equation for phase transitions.
  • Basic skills in calculus for deriving equations related to thermodynamic properties.
  • Research the Clausius-Clapeyron equation and its application to phase changes.
  • Study the relationship between entropy and enthalpy in thermodynamics.
  • Learn how to calculate phase transition properties under varying pressure conditions.
  • Explore the effects of pressure on melting points of substances, particularly ice.
Students and professionals in chemistry and physics, particularly those focusing on thermodynamics, phase transitions, and material science.
glenL
The heat of melting of ice at 1 atm and 0 degree c is +5.9176kj/mol. The density of ice under these conditions is 0.917g/cm^3 and the density fo water is 0.9998g/cm^3
What will the melting point be at 10 atm? Derive necessary equations and make necessary asumptions.
DeltaH and deltaS can be easily calculated, but i was thinking that dp/dt=(s2-s1)/(v2-v1). however i don't know if the formula is correct and how to apply to this problem. Thank you.
This is a good start. Is there a relationship between s, h, and Tm, so that you can express [itex]\Delta s[/itex] in terms of [itex]\Delta h[/itex]?
  • · Replies 18 ·
