Find the Optimal Cut Point on a Hanging Thread
  • Context: Undergrad
  • Thread starter Thread starter deepansu sharma
    Cut Point Thread
The discussion revolves around determining the optimal point to cut a hanging thread with weights attached, focusing on the effects of tension and strain along the thread. Participants explore the implications of cutting at different locations in relation to the weights.
  • Exploratory, Technical explanation, Debate/contested
  • One participant suggests cutting at the top of the thread, reasoning that this point experiences the greatest tension, making it easier to cut.
  • Another participant agrees with the initial guess, stating that any part of the thread below the first weight does not experience tension from that weight.
  • A different viewpoint proposes that cutting anywhere between the ceiling and the first weight would also be effective, supporting the idea that higher tension correlates with ease of cutting.
  • One participant introduces the concept of normal strain, arguing that the top of the thread would have the highest normal strain, which could facilitate cutting due to elongation and thinning of the thread.
Participants generally agree that cutting at the top of the thread is likely the easiest option due to the tension involved, but there are varying opinions on the implications of tension and strain at different points along the thread.
Assumptions about the relationship between tension, strain, and ease of cutting are not universally established, and the discussion does not resolve the optimal cutting point definitively.
Individuals interested in mechanics, material properties, or practical applications of tension in physical systems may find this discussion relevant.
deepansu sharma
a weight is attatched midway to a thread which hangs vertically from a ceiling.another weight is attatched to the bottom end of the thread.where along the thread will it be most easy to cut and why?
What's your initial guess (and why)?
I would say at the top, near the point the thread is attached to the ceiling. Why?, because at that point there is the greatest amount of tension on the thread, which makes it easier to cut.
My thoughts anyway.
I would say that your initial guess is correct, because any part of the thread below the first weight does not experience tension from that weight.
This is assuming it is easier to cut if it is more tense, which I think is a fair assumption.
I would say anywhere between the ceiling and the first weight.
regarding the assumption of higher tension = easier to cut, I would agree; it would flex less as the cutting object pressed against it
The top of the thread due to it having the highest normal strain (change in shape and volume), the thread would elongate and become thinner allowing less work to be done to cut the thread.
  • · Replies 28 ·
  • · Replies 32 ·
  • · Replies 31 ·
