Acceleration on a slant/coefficient of friction
The discussion centers on calculating the distance a block travels up an inclined plane with an initial speed of 6.00 m/s, an incline angle of 30 degrees, and a coefficient of kinetic friction of 0.330. The user initially misapplied the acceleration due to friction and gravity, leading to incorrect calculations. After reevaluating the forces involved, the correct acceleration was determined to be -2.80 m/s², which was then used to calculate the distance traveled up the incline. The final distance calculated was 6.42 m, which did not match the expected answer choices, indicating a need for further refinement in the approach.
  • Understanding of Newton's laws of motion
  • Knowledge of kinematic equations, specifically delta_x = v_initial + 0.5a*t^2
  • Familiarity with the concept of friction, particularly the coefficient of kinetic friction
  • Basic trigonometry, especially in relation to inclined planes
  • Review the derivation of the normal force on an incline and its impact on frictional force
  • Learn how to apply the work-energy principle in inclined plane problems
  • Study the effects of different coefficients of friction on motion up an incline
  • Practice solving similar problems involving inclined planes and friction to reinforce concepts
Students studying physics, particularly those focusing on mechanics and inclined plane problems, as well as educators looking for examples of friction and motion analysis.
Crazdfanatic
A block is given an initial speed of 6.00 m/s as it slides up an inclined plane that makes an angle of 30 degrees with the horizontal. If the coefficient of kinetic friction is .330, how far up the incline will the block go?
I messed around with the equation delta_x = v_initial + .5a*t^2 , not sure how the coefficient of friction works
I tried setting a = - 11.3 m/s/s by using trig because of the slant on the horizon, then using the above distance formula to find the maximum distance it traveled. I tried multiplying the coefficient of friction into the acceleration part of the equation, but to no avail. Please help me figure out what I'm doing wrong. Maybe an explanation of coefficient of friction is all I really need, I don't know.
The coefficient of friction defines the relation between the normal force (exerted perpendicular to the contact surface) and the frictional force (which is parallel to the surface).
Ffrict = u x Fnormal
On a ramp, the normal force is no longer equal to simply mg, which is where the angles come in. Give it another try using these principles.
Okay, so I looked at it again, and this is what I got.
I found the new acceleration by g(u)cos(30) . I ended up getting a = -2.80 m/s/s.
From there, I plugged it into the distance formula above, leaving me with:
delta_x = t(6.00) + .5(-2.80)t^2
I took the derivative with respect to t to find the t that would give me the max distance.
I got this.
0 = 6.00 + (-2.80)t
t = 2.14 s
I plug that back into the above equation to get delta_x.
I ended up getting delta_x = 6.42 m, which is nowhere near any of the answer choices.
Am I even on the right track?
  • · Replies 16 ·
  • · Replies 33 ·
