Speed of light is measured by all observers
The discussion revolves around the question of why the speed of light in a vacuum is measured to be constant (c) by all observers, regardless of their relative motion. Participants explore theoretical, philosophical, and conceptual aspects of this phenomenon, touching on implications in physics and relativity.
  • Some participants suggest that the question is fundamentally about the nature of light and its special status in physics, implying there is something unique about light that necessitates its constant speed across different frames of reference.
  • Others propose that the constancy of the speed of light is a postulate of physics that cannot be further explained, arguing that all scientific theories must start with certain assumptions.
  • A viewpoint is presented that the laws of classical electrodynamics provide a classical understanding of why the speed of light remains constant under Lorentz transformations, though the underlying reasons remain a philosophical question.
  • One participant raises a concern about how time dilation in relativity affects measurements of light speed, questioning the implications of time slowing for moving observers.
  • Another participant emphasizes that while Einstein's theories are widely accepted, there is room for improvement and further exploration of these concepts.
  • Some participants express skepticism towards philosophical conjectures that attempt to derive current physical assumptions from simpler ones, suggesting that such claims are often untestable.
The discussion reflects multiple competing views and remains unresolved, with participants expressing differing opinions on the nature of light, the role of assumptions in physics, and the implications of relativity.
Participants acknowledge that the discussion involves complex philosophical considerations and foundational assumptions in physics, which may not be universally accepted or understood.
protonman
How is it that the speed of light is measured by all observers regardless of their relative motion?
Science news on Phys.org
Think you mean:
Why is the speed of light in vacuum allways measured to c, regardless of the relative motion between the light source and the observer?
Since the speed of light in vacuum is allways measured to c, regardless of the relative motion between the light source and the observer! :wink: :smile:
EL said:
Think you mean:
That is not a serious answer but the way you re-phrased the question is correct.
One suggestion is that space-time is not "real." Therefore, labelling points in the space-time manifold is somewhat arbitrary, including how the axes of the coordinate system are oriented. It is, of course, found that there is a preferred type of motion (constant v as opposed to d2x/dt2 /= 0). Assuming a coordinate system that does not induce a nontrivial d2x/dt2 on free particles, then Maxwell's equations give c, regardless of the further particulars of the coordinate system, including the orientation of the space-time axes.
This is all somewhat philosophical, and, regarding the physics, the popular answer, "that is just the way it is," is valid.
This is not a valid answer. This is something that needs to be understood. Anyone serious about physics should be deeply concerned that this is not understood. If you are just interested in solving equations and answering trivial questions then it is not an issue though.
protonman said: "This is not a valid answer. This is something that needs to be understood. Anyone serious about physics should be deeply concerned that this is not understood. If you are just interested in solving equations and answering trivial questions then it is not an issue though."
The postulates for theories in physics can never be explained. If they could, then those explanations would be based on something even deeper in physics that couldn't be explained, and they'd be the postulates. Some branch of physical science has to be the one that can't say, "Our postulates are based on the theories of a more fundamental branch". That branch is physics.
If having to just accept things like "the speed of light is constant because that's how nature is", seems invalid or unsatisfactory then physics probably isn't for you. Because, trust me, there are a lot more things you'll have to accept, and some of them will make constant light speed seem easy!
Accepting things like constant light speed, hardly relegates physics to just "solving equations and answering trivial questions." Unless you think questions like: "How did the universe begin? How long ago did it happen? What was the universe like back then? What will happen to it?" are trivial. Again, if you do, physics probably isn't for you.
Incidentally, if physicists had spent the past 99 years fretting about why light speed is constant instead of thinking about what it implies, we'd be no closer to answering the questions in the last paragraph than we were in 1905. And where were we then? One example should give you an idea: We had no idea what made the sun hot!
First off I am not asking if physics is right for me. You have no idea what my understanding of physics is. Second, my question is important and useful. What is special about light that observers measurements of space and time must always be such that they ensure that light is measured the same for all observers? There is obviously something special about light. I have my own understanding and explanation but am interested in what other have to say.
Whatever your explanation is, it will depend upon assuming something else is true "because that's just the way it is".
In general such assumptions are accepted until some simpler set of assumptions is found, but there will always be assumptions. So demanding a theory that does not make "that's the way it is" assumptions is pointless.
Of course, if you have a way of deriving the current assumptions of physics from a simpler set of assumptions, that's great. But most scientists will be very skeptical of such a claim, and for good reason. Almost invariably such proposals turn out to be philosophical conjectures that are impossible to test, instead of actual scientific theories.
I agree with master_coda. In science as in virtually any other branch of philosophy, you have to start with assumptions.
protonman, why don't you just show your assumptions and let us see if they are better than Einstein's?
Experiment shows that the speed of light is measured the same for all inertial observers. The laws of classical electrodynamics give a classical view to why it happens, because of the symmetry of those laws under lorentz transformations.
Why it happens is not a question for physicists.
In my unqualified way I find Photonmans question very interesting and more to the point the response so far also.
Relativity if I'm not mistaken suggests that time slows according to velocity. If time is slower for a mass traveling at velocity how can that mass ( or someone traveling on or in that mass) measure the speed of light as 'c' for surely the time dilation would ruin any chance of that?
There is no doubt about Einstiens Brilliance and I don't think this is in dispute. However it is worth remembering that high school physics teaches Einstiens work and the work of others quite thoroughly. What was once frontier physics is now almost common knowledge.
Therefore, it isn't suprising that some one wants to and eventually is bound to improve on it all.
You are mistaken. Relativity says that if someone flies away from you in a spaceship at a significant fraction of the speed of light, it will appear to you as though the events on the spaceship are running slow. To the people on the spaceship, everything looks the same as it always does. One of the central ideas of relativity is that you cannot measure the speed of your spaceship without looking out the window.
- Warren
I never said I had any assumption.
Your attempts to dismiss my question are total bull****. Science is about explaining why things in the physical world are the way they are. Before Quantum Mechanics no one could explain why the sky was blue. QM gave an answer to this. Yes eventually you get to the point where the answer is just "that's the way it is" but science has not reached that point with light.
You claimed to have an explanation. This explanation must require assumptions, or else it is not in fact an explanation. They may be assumptions you consider to be self-evident or obvious, but they still are assumptions.
I agree that there's nothing wrong with asking "why is that?" It's actually a fundamental question in science. But since you haven't actually put forth an explanation, you shouldn't be offended that people are dismissing you.
You come here, state that physics isn't doing a good enough job explaining because it assumes things, claim to have an explanation that fixes everything (an explanation you don't provide) and then get upset when you're dismissed?
Einstein discovered that he could account for the Lorentz transformations in electrodynamics (which had already been discovered by Lorentz, but which wee not well motivated) by assuming the two postulates: Galilean relativity of inertial frames and constancy of the speed of electromagnetic radiation for all inertial frames. So the "reason" for the constant speed is to provide a consistent account of the observed relationships in electrodynamics.
More modern explanations are like this. When you work out minkowski space you have to have a constant to multiply your time units by to convert them to length units, so the all the units of your spacetime vector will be the same. Call this constant c (c for "constant" or "conversion" now, instead of "celeritas"). Then continuing to work through the math you find two things about this constant. First, it has the dimensions of a speed: length over time ("so many length units per time unit"). Second, it turns out to be a Lorentz scalar, meaning it is preserved under Lorentz transformations, meaning in turn that it's the same in all inertial frames. Well that's good news, you wouldn't want your basic definition of what a vector is to vary among different viewpoints!
So now you have the Lorentz transformations with this new constant c in them, and you can easily prove that IF a body travels at that speed THEN it has to be massless. And conversely if a massless body isn't prevented from doing so, it WILL travel at c.
Then you have the word from quantum mechanics that the mass of the photon is zero, and you conclude that it travels at c, which we already found to be a Lorentz scalar, which means that all inertial observers will measure that speed the same. Other massless bodies, like the gluons, are also assumed to move at c, and they also would have their speed invariant between inertial observers.
Does this help at all?
protonman said:
(post #5) "This is not a valid answer. This is something that needs to be understood. Anyone serious about physics should be deeply concerned that this is not understood. If you are just interested in solving equations and answering trivial questions then it is not an issue though."
(post #7) "You have no idea what my understanding of physics is."
Yes I do. Based on what you said in #5, your understanding of physics is negligible. What's worse, with your attitude, it will always be negligible.
But here's a chance for a fresh start. At the end of your post #7 you say: "I have my own understanding and explanation but am interested in what others have to say."
Ok, now you've seen what we have to say; it's your turn. What's your explanation for constant light speed?
Theories operate in a competitive environment. We go from one useful description of reality to a better one over time. The role of science is to help us compare theories and move in a positive direction.
protonman seems to want to skip the preliminaries and go to the end. Good try, but his criticism is a red herring. How can you criticize a theory that works perfectly in its domain? No theory claims to have all of the answers to all questions. Yet, anyway. :)
In the meantime, if protonman has something positive to offer, let's have it.
I would tell you my ideas but I am concerned that you will take then as your own and perhaps publish then in a journal of intellectual thought.
selfadjoint said: "Einstein discovered that he could account for the Lorentz transformations in electrodynamics (which had already been discovered by Lorentz, but which wee not well motivated) by assuming the two postulates: Galilean relativity of inertial frames and constancy of the speed of electromagnetic radiation for all inertial frames."
Einstein assumed "Galilean relativity of inertial frames"? Is that really what you meant?
Ok, let us know when you get them published, and I'll read them then. :wink:
I think it is what he meant, but just to clarify: He did not say that Einstein assumed the Galilean transformation. He said that Einstein assumed Galilean relativity (meaning the postulate that it should not be possible to differentiate inertial frames by doing any experiment that does not make reference to the outside world), which is correct.
- Warren
I am sorry,
I was under the impression that time dilations where a reality and not a just a perception of light speeds...
I don't care about getting them published. Besides the world is probably not ready for my ideas and would most likely reject them due to their ignorance.
Of course. Because when faced with the possibility that either:
A) You are wrong.
- or -
B) You are smarter than everyone else in the world and so nobody else can comprehend your brilliant ideas.
then the answer is clearly B. Possibility A is clearly impossible. :rolleyes:
Scott Sieger said:
I am sorry,
Pions 'at rest' are observed to decay in x microseconds; pions produced by cosmic ray air showers - moving at speeds of z m/s - are observed by Scott, Nereid, Tom, protonman, etc to decay in y microseconds. Hmm, seems pretty 'real' to me.
:wink:
yesterday after having a beer or 12, I wrote a mean post on another thread about aether. It closed quickly. Sorry. I have not been drinking today, So let's see if I can ask a good question (that will not close the thread). If time slow downs as something travels closer and closer to "c",would this suggest that the atomic motion of matter slows, and can it be that something is causing that? Space having some kind of resitance to it. It's not that I believe it is aether, but like the first post, it is hard to accept the answer "it just is".
Scott Sieger said:
I am sorry,
They are a reality, but like velocity, you can only measure it in relation to someone else.
To date, there is no evidence of this "something" causing the motion of matter to slow. It is certainly possible, but without any evidence, it can't be assumed or even theorized. And it works perfectly well to use the current explanation: that time itself is slowing.
All of the laws of the universe 'just are' - either that or they were made by God for a reason only he knows. Either way, you do have to live with that answer.
Russ this is interesting...
Say you are traveling at a velocity that creates time dilations for you the traveller relative to another frame...and as you are traveling you decide to measure the speed of light even though you are in a time dilated state...how could you measure "c" accurately when your tools to measure with are time dilated? Wouldn't the measurement be in error due to time dilation?
Laymans terms to topic question.
If you travel at nearly the speed of light. Let's say 99.99 Percent of it Light still travels ahead of you at light speed. This is because time is distorted to you, Although you felt as if traveling a light year in just a few days, to Earth it still took you a year. 0.001% more than a year to be exact)
Therefor the greater speed you travel the more time is distorted making up the difference.
(fits into equation;)
  • · Replies 19 ·
  • · Replies 50 ·
  • · Replies 25 ·
