Possible Interference Between Key Fob Signals and Other Cars?
  • Thread starter Thread starter DaveC426913
    Cars
The discussion revolves around the potential interference between key fob signals and the electronic systems of nearby vehicles, specifically focusing on an incident where a key fob caused the headlights of another car to flicker. Participants explore the mechanisms behind key fob operation, possible frequency overlaps, and the implications of such interactions.
  • One participant observed that their key fob caused the headlights of a nearby SUV to flicker, raising questions about whether this was due to frequency overlap or a direct electronic interaction.
  • Some participants propose that the two vehicles might operate on similar frequencies, while others suggest that multiple frequencies could be involved for different functions like lights and door locks.
  • Another participant argues that the key fob transmits a very low amount of RF energy, making it unlikely to directly affect other vehicle components, and suggests that the SUV may have a sophisticated alarm system reacting to perceived interference.
  • There is speculation about whether the flickering lights could serve as a warning signal from the SUV's alarm system, although this raises questions about its effectiveness in deterring thieves.
  • Participants discuss the historical context of key compatibility, noting that older non-electronic keys often opened similar vehicles, which could lead to confusion.
  • One participant clarifies that their key fob is not a remote keyless entry system but merely an unlocking mechanism, emphasizing the specific nature of their experience.
  • Concerns are raised about the possibility of electronic key matches causing unexpected interactions, with some humorously suggesting that such occurrences could lead to misunderstandings.
Participants express a range of views on the nature of the interaction between the key fob and the SUV's lights, with no consensus reached on the exact cause or implications of the flickering lights. Multiple competing hypotheses are presented without resolution.
Participants note the complexity of keyless entry systems, including the use of encryption and potential interference from other devices. The discussion highlights the limitations of understanding the specific mechanisms at play without further investigation.
DaveC426913
2025 Award
I came out to my car (a Chrysler) the other day and went to open my doors using my key fob when I noitced that the SUV (not a Chrysler) parked between me and my car flicked its lights. I was about six feet away from the SUV. Every time I pressed my buttons, be it lock, unlock or trunk, this SUV's headlights and signal lights would flicker rapidly several times. (No, it didn't open the SUV's doors.)
I'm not sure if my fob was electronically triggering the SUV's receptors or whether it was a more direct connection, such as the lights were reacting directly to the signal burst from my fob (like an EMP).
Thoughts?
Computer science news on Phys.org
That is quite interesting...it is possible that the two had the same frequency...but that wouldn't explain why the doors didn't open. Maybe there is multiple frequencies(sp), one for lights, one for the opening of doors..this is vague I know, but just a thought...
Your key fob transmits only a minute about of RF energy; there's no way it produces enough power to actually directly affect the relays and other components that are required to turn the headlights on. Also, had it directly affected some circuits, it would have directly affected all circuits, and you'd have windshield wipers and horns blowing and so on, too.
What's much more likely is that the SUV has some kind of sophisticated alarm system, and perceived your nearby key-fob transmission to be some kind of interference. It flashed the lights as a deterrent to any would-be theif who might be trying to trick its keyless-entry system. I've never seen such a feature advertised for an alarm system, but I suppose it would be easy enough to implement, and may exist.
- Warren
Key fobs don't depend on different frequencies to identify themselves -- they depend on digital authentication methods, and generally transmit on just one frequency. The digital transmission includes an identifier indicating which button was pressed.
- Warren
I'd say you've just gone into the second hand SUV business :biggrin: (just a joke of course kids)
That would be interesting if it was a security feature. I'd have thought that the lights flashing would encourage a thief that was potentially trying to break in by indicating they were having some success.
Well, a lot of cars make warning chirps or flash their lights as a warning, before the alarm actually goes off. I was thinking perhaps Dave was observing such a warning.
- Warren
It's probably close enough of a frequency that it "notices" and "acknowledges" it. Gotta run into problems with so many cars.
Haha kind of like in Mastermind?
http://en.wikipedia.org/wiki/Mastermind_(board_game)
:smile: When I was going to college, I got in my car and drove off.
It wasn't until a few blocks later that I reached into the glove box to get something and discovered that that it was someone elses car.
Same colors, key worked fine :rolleyes:
Back in the days of plain ol' non-electronic keys, that was actually pretty common, NoTime. There were only about a dozen different keys for each model of lock, and your key would often open similar cars.
- Warren
The authorization for keyless entry for cars is not trivial simply because there are so many vehicles, all using the same frequency band. There is interference from other keyless entry devices nearby, for example. In some cases harmonics from other transmitters can interfere.
There is encryption, too. No surprise there. A block 64 bit cipher, KeyLoq, is one commonly used algorithm (its a trade name), used for keyless entry systems for homes and automobiles.
This cryptanalysis paper:
http://eprint.iacr.org/2007/055.pdf
is an attempt at breaking the KeyLoq cipher.
- Warren
Yea, I know about the old key problem.
It's just that if I hadn't ended up searching the entire car for the papers I needed for the appointment I was going to I might have driven it around for weeks before I found out.
They were that close a match.
It's not that I just wasn't paying attention.:redface:
I wonder if Dave got an electronic key match with an invalid command set.
Otherwise, I might think half the cars in a parking lot might flash if it was just some interference effect.
Then the owner of the SUV might have been nearby playing head games :smile:
If there is a billion to one chance of something then its going to happen to 6 people. :smile:
I should clarfiy:
- it is not a remote keyless entry - it is simply an unlocking mechanism
- there is no possbile way it was a trick, unless the trickster was sitting on my thumb, there's no way they could have known when or how often I pressed the button
- the lights flickered only faintly, but definitely a sustained flicker - very much as if it was reacting to a digital signal several fractions of seconds long
- if the flickering was any sort of warning, it was a pretty pathetic one
I'd like to have been a fly on the wall for that phone to the police.
Hello, officer? Um. I appear to have stolen a car.
  • · Replies 33 ·
