Distance Travelled by Doubled Mass Block with Unchanged V0
  • Thread starter Thread starter zellster87
    Block Mass
The problem involves a block sliding on a surface after a pushing force is removed. The scenario examines the effect of doubling the mass of the block while keeping the initial velocity constant, and it asks for the distance the block slides before stopping, expressed in terms of a given distance D.
  • Participants discuss the relationship between force, mass, velocity, and distance, with one participant expressing uncertainty about how to formulate the problem. Others suggest considering the effects of mass on the motion of the block and question the constants and variables involved.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some guidance has been offered regarding the setup of equations, but no consensus has been reached on the approach to take.
It has been clarified that there is no friction involved in the problem, and the original poster emphasizes that a numerical answer is not required, only a relationship expressed in terms of D.
zellster87
A block pushed along the floor with velocity V0 slides a distance D after the pushing force is removed.
If the mass of the block is doubled but its initial velocity is not changed, what distance does the block slide before stopping? Express your answer in terms of D.
F = ma
My only problem with this question, is that I simply don't know how to relate force, velocity and distance into an equation. I've tried rearranging Newtons, but I can seem to get the right ratio. Thanks for you time.
Here's my take- when you stop pushing the block it will SLOW DOWN (this is acceleration, just negative).
F=ma
So what are you constants 1?
What is your variable?
what level are you at? is friction involved in the problem, or did you type the whole thing?
There is no friction invloved. What i typed, is exactly, and everything the problems gives. Their not looking for a numerical answer. Something like 0.5d or 0.25d or something.
ok, so assume F stays the same you can set up 2 equations- what would they look like ?
  • · Replies 18 ·
  • · Replies 45 ·
  • · Replies 23 ·
