How Do You Plan Chemistry Experiments for Molar Enthalpy and Recrystallisation?
  • Thread starter Thread starter meawinner
    A-level Chemistry
The discussion revolves around planning chemistry experiments to measure molar enthalpy changes and to purify a solid compound through recrystallisation. Participants seek guidance on experimental design and methodology for both tasks, which involve theoretical and practical aspects of chemistry.
  • Homework-related
  • One participant expresses confusion about how to conduct a calorimetry experiment to measure the molar enthalpy change of magnesium metal in different concentrations of hydrochloric acid.
  • Another participant suggests using calorimetry and preparing various solutions to measure enthalpy changes, proposing to plot enthalpy change versus concentration.
  • There is uncertainty regarding the identity of "H," with one participant clarifying that it refers to an unknown compound, not hydrogen.
  • Participants discuss the process of recrystallisation, explaining that it involves dissolving a sample in a solvent at high temperature and allowing it to crystallize upon cooling.
  • A later reply outlines a method for recrystallisation, emphasizing the importance of solubility at different temperatures and the filtration process to separate impurities.
Participants generally agree on the basic principles of calorimetry and recrystallisation, but there is no consensus on the specifics of the experiments, particularly regarding the identity of the compound "H" and the details of preparing solid samples.
Participants mention the need for data on solubility at different temperatures, which may affect the recrystallisation process. There is also an acknowledgment of potential sample loss and purity issues during recrystallisation.
This discussion may be useful for students learning about calorimetry and recrystallisation techniques in chemistry, as well as those seeking to understand experimental planning for measuring enthalpy changes and purifying compounds.
meawinner
Hi I got given these 2 planning q's to do by my teacher but I don't have a clue how to do the actual experiment. If i knew that much then I would b able to write about it. Could n e 1 help me please
Plan an experiment that would enable you to measure the molar enthalpy change of the reaction between magnesium metal in different concentrations of dilute hydrochloric acid. :eek:
I thought about this question and I thought could it be the calorimeter with the zinc and the cup and the thermometer but then it says diff concentrations of HCl so i got a bit confused so could some1 please help me.
Plan an experiment to purify solid H by recrystallisation.
You are required to plan an experiment by which a pure sample of H could be prepared, from an impure sample of solid, ready for a melting temperature determination. Your method will involve recrystallising H from a suitable solvent. Assume that you have access to data giving the solubility of H in different solvents at different temperature.
I looked at this question and the first thing that hit me was what is recrystalisation? and what has it got to do with the solubilities? Please help me!
Thank you for anyone who may be able to help me.
meawinner
Chemistry news on Phys.org
If you're measuring enthalpy, then yeah, do a calorimetry experiment. It's easy enough to just make up a variety of solutions with different concentrations and measure these. Then you can just plot enthalpy change versus concentration to work out molar enthalpy.
I'm not sure what you mean by the second one. Do you want to prepare solid H2? I have no idea how to do that. I mean, H2 is a gas even at about 20 K.
Recrystallisation is a method where you prepare a sample, then dissolve it and then let it crystallise out of solution. It increases the purity of your sample.
Thanks for your help and H is not hydrogen but a letter that stands for an unknown compound.
Alright, so say your sample is slightly soluble in water, and the solubility greatly increases with heat. Figure out from the table how much water will dissolve your sample at 100 degrees C. Add that much water and boil. When you get to one hundred degrees C, all of your sample will dissolve. Now take off the heat and cool to 0 degrees. Your sample will crystallize out of solution while the impurities remain in the solution. This is recrystallization. You can then just filter out the water. You'll lose a little bit of the sample, and it won't be exactly 100% pure, but you can get pretty close and always do another recrystallization.
