Experiments regarding C of A.M.
  • Thread starter Thread starter ACLerok
    Experiments
This discussion focuses on experiments demonstrating the conservation of angular momentum, specifically through a thought experiment involving a gyroscope and a spring-mass system. The proposed setup includes a vertical rod with a spring attached, where an external torque is applied to initiate rotation. The analysis concludes that changes in angular velocity are influenced by the dynamics of the mass attached to the spring, with the prediction that angular velocity increases as the spring contracts and decreases as it lengthens.
  • Understanding of angular momentum conservation principles
  • Familiarity with gyroscopic motion and its effects
  • Basic knowledge of spring dynamics and forces
  • Ability to analyze two-dimensional motion in physics
  • Research the mechanics of gyroscopes and their applications in physics experiments
  • Study the mathematical modeling of angular momentum in rotating systems
  • Explore the effects of external torque on rotational motion
  • Investigate the role of centrifugal force in dynamic systems
Physics students, educators, and researchers interested in experimental mechanics and the principles of angular momentum conservation.
ACLerok
I'm in desperate need of any testing experiment that shows the conservation of angular momentum. It should be something where an objects shape or radius changes while it spins, and calculate the angular momentum at each moment in time to see if it's conserved. If anybody has any ideas at all, PLEASE leme know! Thanks
Why don't u consider making ur own Gyroscope...and spin it while sitting in a chair such that its axis of spin is perpendicular to the ground. Now make it parallel to the ground . U will find that the chair now rotates
Well, this is possibly a dumb thought experiment that can't be realized in practice, but anyways:
Attach to a vertical rod L a spring K standing normal to L.
K is sufficiently stiff so that it can't bend downwards much.
Attach to K at the end an object O of mass m.
Apply an external torque T to L, such that the system rotates around the axis L with angular velocity w0.
Due to the centrifugal force on O, K will stretch a bit in its length direction.
Now remove T, and assume that L is free to rotate about the vertical but that it's centerline doesn't move (for example, placing the lower part of L in a closely fitting container.
We assume that the friction between the container wall and L is negligible, at least over the duration period of the experiment.
MECHANISM OF CONSERVATION OF ANG. MOM::
Since we neglect the effect of friction on L from the container, changes in angular velocity w(t), should come from the dynamics associated with O.
The only forces acting on O is the centrifugal force, the spring force, and gravity.
I will assume that the motion of O remains 2-dimensionsial, in the plane normal to L.
(This is probably incorrect; I suspect rod L would jump up and down somewhat, being correlated with the interplay of gravity and the spring force's component normal to K's length direction, making O oscillate somewhat in the vertical.)
We look at the component of angular momentum along L.
In the 2-D approximation, we see:
a) The forces on O (centrifugal and spring force) are radial (along K), and, so the rate of change of angular momentum along L should be zero.
b) The 2-D approximation implies therefore that m*r(t)^(2)w'(t)=constant.
(r(t) is K's length at t)
The prediction should therefore be:
When K contracts, w(t) should increase, when K lengthens, w(t) should decrease..
  • · Replies 40 ·
