How Does Differential Calculus Apply to Filling a Jug with Liquid?
  • Thread starter Thread starter eeriana
    Concentration
The discussion focuses on solving a differential calculus problem involving the filling of a one-gallon jug with liquid. The first part requires finding the general solution to the equation dx/dt = x - x^2, while the second part involves determining the time it takes for the jug to be 90% full, given a liquid inflow rate of 1/4 gallon per minute. Participants clarify that the rate of liquid flow is proportional to both the volume of liquid and air in the jug, leading to the equation dV/dt = k(V)(1 - V), where k is the proportionality constant derived from the initial conditions.
  • Differential equations, specifically separable equations
  • Understanding of proportional relationships in calculus
  • Basic knowledge of fluid dynamics concepts
  • Familiarity with initial value problems in differential calculus
  • Study the derivation and application of separable differential equations
  • Learn about initial value problems and their significance in real-world applications
  • Explore the concept of proportionality in calculus and its implications in fluid dynamics
  • Investigate the relationship between volume, rate of flow, and time in fluid systems
Students studying calculus, particularly those focusing on differential equations, as well as educators seeking to enhance their understanding of fluid dynamics in mathematical contexts.
eeriana
2 part question: part one is supposed to be a hint to part two.
1) find the general solution to the equation: dx/dt = x - x^2
2)A one gallon jug is half full of a liquid and half full of air. Additional liquid is being pumped in at a rate of 1/4 gallon per minute. If the rate at which the liquid flows into the container is proportional to both the volume of liquid in the jug and the volume of air in the jug, how long will it be before the jug is 90% full of liquid?
dx/dt = r(i)c(i) - (r(o)/V)x
If I have calculated the first part correctly, I came up with t = ln(x/1-x) - C
I know the rate in of the liquid is .25 gal/min. Rate out is 0. I am not seeing the connection to the first equation. If someone could point me in the right direction, I'd appreciate it.
Thanks
This is meaningless without saying what the variables mean. I might assume that "x" is the amount of liquid in the jar, but, in that case, what is V? Are "r(i)" and "r(o)" "rate in" and "rate out"? But what is c(i)?
So what is x as a function of t?
[/quote]I know the rate in of the liquid is .25 gal/min. Rate out is 0. I am not seeing the connection to the first equation. If someone could point me in the right direction, I'd appreciate it.
Thanks
[/QUOTE]
It took me a while to make sense of it but I think that by "the rate at which the liquid flows into the container is proportional to both the volume of liquid in the jug" they mean the rate is jointly proportional: that is dV/dt= k(V)(A) where V is the amount of liquid in the bottle at time t and A is the amount of air in the bottle at time t, both measured in gallons. Since the bottle holds one gallon, A= 1- V so the equation is dV/dt= k(V)(1- V).
Unfortunately, now the "Additional liquid is being pumped in at a rate of 1/4 gallon per minute." makes no sense! I can only assume that is to tell you the "constant of proportionality", k, and guess that it is only at the beginning, at t= 0 that the rate is 1/4 gallon per minute. Since V(0)= 1/2, A(0)= 1/2, k(V)(A)= k(1/2)(1/2)= k/4= 1/4 so k= 1. If that was what was intended, they should have said "initially" the liquid was being pumped in at a rate of 1/4 gallon per minute.
c(i) is concentration in.
Thanks
[/QUOTE]
Unfortunately, now the "Additional liquid is being pumped in at a rate of 1/4 gallon per minute." makes no sense! I can only assume that is to tell you the "constant of proportionality", k, and guess that it is only at the beginning, at t= 0 that the rate is 1/4 gallon per minute. Since V(0)= 1/2, A(0)= 1/2, k(V)(A)= k(1/2)(1/2)= k/4= 1/4 so k= 1. If that was what was intended, they should have said "initially" the liquid was being pumped in at a rate of 1/4 gallon per minute.[/QUOTE]
so k is the proportionality? I am not quite sure where k came from. I am also not getting the connection to the first equation, and my instructor said that the first equation is a hint to solving the other. Am I missing something?
Thank you for your help
