| Thread Closed |
AJAX versus JAVA |
Share Thread | Thread Tools |
| Feb11-08, 01:28 PM | #1 |
AJAX versus JAVA
Which one is better?
It turns out that AJAX suffers from the fact that 90% of development time is spent trying to work around intricacies of specific platforms, which is why google came up with a library that converts JAVA applets into AJAX code. But why not stick with JAVA anyway? Can't JAVA produce a site that looks like this forum? Can't it provide all the same functionality but in different code, and much more responsively? |
| Feb11-08, 05:55 PM | #2 |
Admin
You can use both together. You could certainly build a system like PF with JAVA (JSP...J2EE). AJAX is a technique rather than it's own language. The technique utilizes XML and Javascript to process a user request immediately instead of having to refresh the page. So yes you can use JAVA and AJAX together to create a system like PF.
Google likely created a library to convert applets to javascript because applets are resource hogs, have poor usability and need plugins to operate. Javascript is platform independant as well. |
| Feb11-08, 10:40 PM | #3 |
I think JAVA would much slower than AJAX for creating a forum like PF. Much slower. HTML loades much faster than a JAVA applet. But I guess applets could be designed to load faster.
AJ |
| Feb12-08, 12:51 PM | #4 |
AJAX versus JAVABut all JAVA applets I've seen look like FLASH graphics or windows dialog boxes, not browser text. Anyone know if browsable forum text can be done with JAVA? |
| Feb12-08, 12:56 PM | #5 |
Admin
. JAVA is a programming language. AJAX is a programming technique that uses javascript and xml. You can build a forum with JAVA with AJAX techniques, but you can't build a forum with just AJAX (javascript and xml).If you want to use an applet then yes it is fairly similiar to flash. However you can easily use JAVA in the form of JSP, which is comparable to PHP, ASP, ROR, CF... |
| Feb12-08, 01:30 PM | #6 |
- As many pictures that are shown when you click on links in HTML - As a WIN32 application that downloads maps into memory and shows the bit you're looking at. Is customer allowed to compare WIN32 with plain HTML or is it apples with oranges? I am aware of the philosophy of AJAX, which is all about using standard web things like javascript xml and asp in a way that gives instantaneous response from user input. JAVA, I've only used as a substitute for C++ in desktop applcations, so I wonder if it can control the display of text in a browser like javascript does, that's my question. > If you want to use an applet then yes it is fairly similiar to flash. However you can easily use JAVA in the form of JSP, which is comparable to PHP, ASP, ROR, CF... Not sure what this parade of acronyms is saying to its users, but for me, does JSP look like physicsforums.com? Does JSP respond instantaneously, ie you get from the server all new forum posts and show the user the topics he clicks on instantaneously? In fact I wanted to design forum software like this. It would be super-responsive, it would be held on member's local hard disks, members would be able to ignore certain categories, etc. |
| Feb12-08, 01:50 PM | #7 |
Recognitions:
AJAX can be compared to (client-side) Java applets or to server-side Java like J2EE. Server-side Java can be used with AJAX, or a Java applet can transfer data to a server with XML (though not AJAX per se), but that's about it.
| Feb12-08, 02:16 PM | #8 |
Admin
| Feb12-08, 02:32 PM | #9 |
| Feb12-08, 02:40 PM | #10 |
Admin
| Feb12-08, 02:46 PM | #11 |
> So in conclusion you could still use AJAX with your application development, but it still needs a server side component
How will I save messages onto client hard disk? |
| Feb12-08, 02:48 PM | #12 |
Admin
| Feb12-08, 02:52 PM | #13 |
I tried this with javascript once, and it didn't exist, "for security reasons". Java applets, probably have the same problem, and they don't look like physicsforum.com, they look like flash.
Can't believe it is so hard to save on disk on the client side. There's got to be a way. |
| Feb12-08, 02:58 PM | #14 |
Admin
| Feb12-08, 03:02 PM | #15 |
Well the whole idea is something that works without users installing anything, just use their browser, and enjoy interactivity like that of googlemaps. Googlemaps reloads maps every time you visit, my forum has to only load each piece of data once and save it to disk (or cache?)
| Feb12-08, 03:03 PM | #16 |
Remember JSP, ASP, PHP, all of these are what they call stateless connections. Java runs in it's JVM and can maintain state with the server, the others must make round trips to the server. To "save messages" your going to have to maintain somesort of state on the client machine. Cookies are a way, or have the server maintain a message read/not read list for each unique user. This is one of the biggest pains with web technologies. With a java applet running inside a JVM your essentially running a stand alone, statefull application that can interact with the server, and the client file system just like any other W32 app.
| Feb12-08, 03:08 PM | #17 |
How much data can I save in cookies?
| Thread Closed |
| Thread Tools | |
Similar Threads for: AJAX versus JAVA
| Ajax vs. Flash | Computing & Technology | 10 | ||
| Ajax problem | Programming & Comp Sci | 1 | ||
| Ajax Problem | Programming & Comp Sci | 15 | ||
| Ajax in this forum | Forum Feedback & Announcements | 3 | ||
| Python/Perl/PHP versus Java | Computing & Technology | 27 | ||
