Designing an Impact Force Testing Device
The original poster is designing a device to deliver a specific impact force of 250 to 300 g's to an electrical device housed in plastic. The setup involves dropping a steel plate of specified dimensions from a height to achieve the desired impact force upon hitting a steel base plate. The poster seeks guidance on calculating the necessary height and weight of the plate to ensure consistent test results.
  • Some participants discuss the relationship between energy, momentum, and impact force, noting the importance of understanding how quickly the block stops upon impact. Others suggest that the material properties of the surfaces involved will affect the results.
Participants have provided insights into the complexities of calculating impact forces, emphasizing the need for experimental data rather than purely theoretical calculations. Suggestions include using accelerometers for measurement and considering the effects of material deformation during impact.
The original poster is not a physics student and is seeking practical advice for their design project. There is an acknowledgment that precise calculations may require advanced modeling techniques, which may not be feasible for the poster.
Roscoe48176
I am creating a device to provide 250 to 300 g's of impact force to an electrical device in a plastic housing. I would like to lift a steel plate approximately 16" x 16" X thickness "T",, to a height of "Y" and release it. It would fall at the rate of gravity, impacting a steel base plate and come to rest. The goal is to determine the weight of the plate based on it's thickness and set the height required to create the desired impact force of 250-300 g's. The test must be able to be repeated with consistent results. I have designed the tool, but lack the information requested above.
F=Ma ?
I am not a physics student,, I am a product designer trying to test the impact forces placed on a device. Thank you.
You can't work it out from that.
You can calculate how much energy/momentum a falling block will apply quite easily but to know what force it will apply to the object you need to know how quickly the block will stop - which depends on how the test object will deform.
It's a bit like dropping something on the floor, the same mass dropped on a concrete floor will experience much greater shock than one dropped on wood - because the wood deflects to slow the object down over a longer time and so has less accelearation.
mgb_phys,,
Thank you for the reply.
The base plate of the testing device will be 16" x 16" x 2" thick steel plate. The device will rest on a concrete floor to run the test. 4, 1/2" diameter steel rods will be mounted into the base plate and slide through the mounting plate to guide the mounting plate up and down.
Is there anything else I can provide to assist you?
There is no practical way to calculate this - without doing CFD modelling of the part and for such a high force over a short time this wouldn't be remotely accurate.
The problem is that G force will peak over a very short time - it doesn't take a very big change in the design to give you 100g for 2.5us rather than 300g for 1us.
The best I can suggest is to get some accelerometers, attach them to the plate and experiment with the peak shock - this has got a lot easier since fast digital storage scopes were invented!
thanks for your help,,, I'll work on it from that angle
Call Bruel & Kjaer. Ask for a sales engineer to drop by. They'll sell you what you need.
