Positive direction of the X axis?
The problem involves determining the x and y components of a vector in the xy plane, given its direction of 230° counterclockwise from the positive x-axis and a magnitude of 2 m.
  • Participants discuss the interpretation of the angle and its implications for the vector's components, questioning the relationship between the angle and the right triangle formed by the components.
Some participants have offered insights into the geometry of the problem, suggesting the use of right triangles to find the components. Others have noted the importance of considering the quadrant in which the vector lies, leading to discussions about the signs of the components.
There is mention of potential confusion regarding the angle's measurement and the quadrant in which the vector is located, as well as the need to ensure calculators are set to degree mode for accurate calculations.
lgen0290
What are the x and y components of a vector a in the xy plane if its direction is 230° counterclockwise from the positive direction of the x-axis and its magnitude is 2 m?
My main issue is I'm not sure where counterclockwise from the positive direction of the X axis is. I'd assume that the x and y components wouldn't form a right triangle with the 2m vector being the hypotenuse if the angle is 230°.
Help, I'm lost here.
The positive side of the x-axis points to the right, and this vector apparently forms an angle of 230 degrees to it.
I don't know if you done anything on polar coordinates, but this is very similar to that. On a polar graph, there's only one axis and instead of the y axis, the second coordinate refers to a rotation about the origin where 0 degrees is flat on the positive x axis.
Sounds like your teacher has picked out the next topic and is leading you into it with a coordinate system you're already familiar with.
In this drawing the point B is the (0,0) origin, AE is the x axis, and DC is the y axis, right?
Counterclockwise is in the ↺ direction.
If you draw the 230°, 2m vector coming out of B and call its endpoint F, it's going to be between BA and BD, right? Can you see that it would make two right triangles where F lines up perpendictularly to the axes? You would use those triangles to calculate the x and y components.
The places you'll be marking off on the axes will be negative but you can ignore that; all you care about is that it's a right triangle, so you can turn it around and do your calculations with positive values and you'll still get the correct answer.
Thanks.
That would give me a right triangle in the third quadrant with a 50 degree angle.
My y component would then be sin(50)*2, right? The X would then be sin(40)*2?
OK, I tried what I concluded above and there is a problem somewhere, I can't figure out where though. The answer is not the correct answer.
You are correct that the values from the right triangle would be 2 sin(50) and 2 cos(50)= 2 sin(40) but both x and y are negative in the third quadrant.
Actually, if you are using a calculator, you would do better just to enter 2 cos(230) and 2 sin(230).
Oh, and be sure your calculator is in degree mode!
Consider the x-y coordinate plain. The positive x-axis is 0 degrees, the negative x-axis is 180 degrees. Likewise, the positive y is 90 and the negative y is 270. If your vector is defined by these polar coordinates, yours would be somewhere in the third quadrant, correct? Use this to form your triangle and your components, and you can then use trig to get the components.
  • · Replies 16 ·
  • · Replies 21 ·
