Ballistics Formulae: Distance Traveled Without Air Resistance
The discussion focuses on the formulas for calculating the distance traveled by a projectile in ballistics, specifically when air resistance is neglected. It highlights that the distance formula changes when the projectile does not travel over flat ground, as the trajectory forms a parabola. The effects of air resistance, which depend on the projectile's area and speed, require differential equations for accurate modeling, particularly considering varying air density at different altitudes.
  • Understanding of basic physics principles related to projectile motion
  • Familiarity with differential equations
  • Knowledge of how air resistance affects motion
  • Concept of parabolic trajectories in physics
  • Research the derivation of projectile motion equations without air resistance
  • Study the impact of air resistance on projectile motion using differential equations
  • Explore the effects of varying air density on projectile trajectories
  • Learn about numerical methods for solving differential equations in physics
Physics students, engineers, and anyone interested in understanding projectile motion and the effects of air resistance on trajectories.
Unredeemed
I'm writing a talk on ballistics and was looking for the formula for the distance traveled by the projectile. However, all the formulae I have found exclude air resistance. I understand that the effect of air resistance depends on how stream-lined the projectile is, but is there not a general formula?
Also, the formula for distance traveled (when air resistance is neglected) changes if the projectile is not traveling over a flat surface. Why is that?
If anyone has the answers to those two questions you'd be a real life saver.
The air resistance is generally proportional to area and the square of the speed, since the resitance acts to reduce the speed, the resistance is constantly changing which means the speed is alsways changing - you have to write this as a set of differential equations. If you wanted to do it accurately you also have to account for the different density of air at different heights in the trajectory.
The reason the path only applies to flat ground is simple - sketch the path of the projectile ( a parabola ), now draw the ground where it lands higher - it's obvious that the parabola cuts the ground at a closer point. Imagine if the ground was high enough that it reached upto the maximum height of the projectile - then it would only travle half as far.
thanks a lot, that's exactly what I needed to know.
  • · Replies 23 ·
  • · Replies 19 ·
  • · Replies 22 ·
