Finding Ratio Between Reduced Circumference & Radius of a Black Hole
The discussion revolves around the relationship between the reduced circumference and the actual radius of a black hole, particularly within the framework of general relativity. Participants explore various methods of measuring distances in the context of warped spacetime and the implications of these measurements on the understanding of black holes.
  • Some participants note that the concept of "actual radius" is problematic in general relativity, comparing it to measuring distances on a map and suggesting that it depends on the method of measurement used.
  • One participant describes methods for measuring distances between observers outside the event horizon, including using a plumb line and light signals, highlighting that these methods yield different results.
  • Another participant questions the omission of constants such as c and G in calculations, seeking clarification on their relevance to the problem.
  • There is mention of deriving the Newtonian approximation for distance using integrals, with a suggestion that the mass must be small or that observers must be far from the mass for the approximation to hold.
  • Several equations related to the dynamics of objects falling into a black hole are presented, including expressions for horizon to crunch distances and the relationship between coordinate and proper distances.
  • One participant discusses the reduced circumference in the context of rotating black holes and its relation to the Schwarzschild radius, indicating that the reduced circumference remains consistent across different black hole types.
Participants express differing views on the definition and measurement of "actual radius," with no consensus reached on the best approach or interpretation. Multiple competing methods and perspectives on the topic remain unresolved.
Limitations include the dependence on definitions of distance and the unresolved nature of the mathematical steps involved in deriving various relationships. The discussion also highlights the complexity of measuring distances in curved spacetime.
CJames
Much of general relativity is expressed in terms of the r-coordinate, or the reduced circumference. That is, since space is warped, the actual radius will be different than the reduced circumference, which is found using C = 2 pi r. Does anybody know how to find the ratio between the reduced circumference and the actual radius?
There's a problem here with the concept of "actual radius". It's like asking for the distance on a flat map between two points on the Earth. It all depends on which map projection you use.
There are various possible methods of measuring radial distances, including for example rulers, light time, and other methods which relate to displacement within a background coordinate system (the "map"). However, none of these currently qualifies to be called the "actual radius".
As Jonathon Scott has said, the concept of spatial distance is somewhat problematic in general relativity. In this case, the spacetime inside the event horizon is not stationary, [itex]r[/itex] is a timelike coordinate inside the event horizon, (the singularity at) [itex]r=0[/itex] is a line "on" a spacetime diagram, not a point at the centre of a sphere, etc.
Here are the details for a couple of the methods that Jonathon mentioned.
Consider two observers outside the horizon that hover at constant [itex]r=r_1[/itex] and [itex]r=r_2[/itex], with [itex]r_2 > r_1[/itex], and with both observers having the same constant values of [itex]\theta[/itex] and [itex]\phi[/itex]. The observer at [itex]r_2[/itex] drops a calibrated plumb line (a tape measure!) down to the observer at [itex]r_1[/itex] such that the line ends up stationary with respect to both observers. How much tape does the observer at [itex]r_2[/itex] unwind?
[tex] \left[ r\sqrt{1-\frac{2M}{r}}+M\ln \left( r-M+r\sqrt{1-\frac{2M}{r}}\right) \right] _{r_{1}}^{r_{2}}[/tex]
This is found by integrating the Schwarzschild metric with [itex]dt=d\theta =d\phi =0[/itex],
[tex] ds = \left( 1-\frac{2M}{r}\right) ^{-\frac{1}{2}}dr,[/tex]
from [itex]r_1[/itex] to [itex]r_2[/itex].
Another method is for one hovering observer to bounce a light signal off a mirror held by the other observer, and to define distance between the observers as half the round trip light travel time (with [itex]c=1[/itex]).
I gave the details for this https://www.physicsforums.com/showpost.php?p=928277&postcount=19".
Not that these two methods give different answers!
May I ask why c and G are left out in the calculations? I'm trying to solve a similar problem where I have to express actual length with terms of coordinate distance, so it would help me to understand!
In the above M=Gm/c^2, where m is the mass.
Okay thanks! How would you correctly derive the Newtonian approximation for the distance with this integral? I would only guess that the mass either would have to be relatively small or that the observers r1 and r2 stay far away from the mass.
If you go far enough away so M/r << 1 you're be in flat space and the distance is r1- r2. But I doubt if that solves your problem, which is - you haven't defined 'actual length'. There is 'proper length' which is defined operationally as George Jones has clearly explained.
George Jones has probably already answered the question but here's a few equations that you might find of interest-
In all cases a=J/mc and M=Gm/c2 Horizon to crunch distance for an object falling radially from rest at infinity (rain frame) for a static black hole-
[tex]\tau_{rain}(2M \rightarrow 0)=\frac{4}{3}M[/tex]
divide by c to get the horizon to crunch time for an object falling radially from rest at infinity.
Horizon to crunch distance for an object falling radially from rest at the event horizon (drip frame) for a static black hole-
[tex]\tau_{max}(2M \rightarrow 0)=\pi M[/tex]
divide by c to get the horizon to crunch time for an object falling radially from rest at the event horizon. On a slightly different note, for an observer hovering at a small Schwarzschild distance [itex]\Delta r[/itex] above the horizon of a black hole, the radial distance [itex]\Delta r'[/itex] to the event horizon with respect to the observer's local coordinates would be-
[tex]\Delta r' =\frac{\Delta r}{\sqrt{1-\frac{2M}{2M+\Delta r}}}[/tex]
This shows that coordinate-wise an observer could 'hover' within 100 mm of the event horizon of a 3.7e+6 sol static black hole but from the observers perspective, the distance would appear to be ~33 km to the EH.
While Dr’ doesn’t give you a specific radial distance from a static observer to the singularity, it does at least give the proper distance from a static observer to the EH. This distance is relative to the velocity of the approaching observer and will reduce exponentially(?) the more the observer picks up speed, eventually reducing to radial distance=coordinate distance (i.e. dr’=dr) when the speed of the infalling observer matches that of the rain frame. This of course changes once the event horizon has been crossed.As stated, the reduced circumference for a static black hole is [itex]r=C/2\pi[/itex]. In the respect of a rotating black hole-
Coordinate radius at event horizon (r)-
[tex]r_+=M+\sqrt{M^2-a^2}[/tex]
But the reduced circumference (R) at a specific coordinate radius (r) is-
[tex]R^2=\frac{\Sigma^2}{\rho^2}sin^2\theta[/tex]
Where
[tex] \] <br /> \Sigma^2=(r^2+a^2)^2-a^2\Delta sin^2\theta\\ <br /> \\ <br /> \Delta= r^{2}+a^{2}-2Mr\\ <br /> \\ <br /> \rho^2=r^2+a^2 cos^2\theta\\ <br /> \[ [/tex]
Which is related to the frame-dragging effect (you can see the equation for the reduced circumference expressed clearly in some forms of Kerr metric). The reduced circumference (in the azimuth plane at least) at the event horizon of a rotating black hole [itex](R_+)[/itex] is equal to the event horizon radius for a static black hole [itex](R_s)[/itex] of the same mass which means the Schwarzschild radius is still related to the event horizon in a rotating black hole even though the EH appears to reduce coordinate wise [itex](r_+)[/itex]. This applies every time regardless of mass and spin.
Incidentally, the same applies to the (inner) Cauchy horizon [itex]\left(r_-=M-\sqrt{M^2-a^2}\right)[/tex], regardless of how small the coordinate radius is (i.e. for a spin of a/M=0.1, the inner Cauchy horizon coordinate radius would be fairly insignificant compared to the outer event horizon) the reduced circumference of the Cauchy horizon [itex](R_-)[/itex] also equals the Schwarzschild radius (in the azimuth plane). This may be just a geometric curiosity.<br /> <br /> When [itex]a[/itex] reduces to zero, the equation for R reduces to [itex]r=C/2\pi[/itex]. <br /> <br /> It’s worth noting that the reduced circumference for a rotating black hole is not the proper distance from the observer to the singularity. In some hypotheses, mass inflation at the Cauchy horizon causes the curvature scalar to diverge at the IH so technically r=0 (in respect of proper distance) might be at the IH.<br /> <br /> In respect of the azimuth plane only, the equation for R can be reduced to-<br /> <br /> [tex]R^2=r^2+a^2+\frac{2\ Ma^2}{r}[/tex][/itex]
  • · Replies 51 ·
  • · Replies 30 ·
  • · Replies 29 ·
  • · Replies 18 ·
  • · Replies 67 ·
  • · Replies 17 ·
  • · Replies 20 ·
  • · Replies 37 ·
