Thread Closed
Rate of change
Share Thread Thread Tools
Feb16-08, 06:18 PM   #1
Rate of change
A liquid is being poured onto a level surface making a circular pattern on the surface. Find the rate of change of the area covered on the surface with respect to the radius when the radius is 20cm.
2. Relevant equations
Surface area = (Pi)r^2
3. The attempt at a solution
Well, what's there to do? If you find the surface area, it's 1256 but what do you do after that? Only one numerical value is given so there's not much to work with. And I don't even know how the answer's supposed to look like - is it gonna be in cm, cm^2...Can somebody get me started here...
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Feb16-08, 06:51 PM   #2
Whenever you see that RATE OF CHANGE is being asked of, then this should indicate that you should be using derivatives.
Now it is asking for rate of change of the Surface area. So find d(SA)/dt.
Feb16-08, 09:58 PM   #3
The question is asking you how quickly is the area of the puddle increasing, given that the puddle already has a radius of 20cm.
Thread Closed
Thread Tools
Similar Threads for: Rate of change
Thread Forum Replies
rate of change Calculus 1
Related Rate -finding the Rate of Change of an Angle Calculus & Beyond Homework 5
rate of change Introductory Physics Homework 5
Measuring rate of reaction via rate of temperature change Chemistry 3
Rate of change General Math 3
